Motorcycle.com Classifieds!ShopTriumph.comMotorcycle.comTrident-Exhausts.comSpringfield ArmoryAnnitori DistributingRacerPartsWholesaleCycleGear.comAdvanstarMotorcycleShowsBikeBandit
BikeBandit
Old 05-27-2007   #1 (permalink)
Leo
Yesterday I changed the oil and filter in my Bonnie. Used AMSOIL 20W-50 full sythetic motorcycle oil. Filled tank with 87 unleaded today. Immediately after I put gas in tank, bike would not start. Lots of clicking noises, but nothing firing. Battery seems to be fine. Is this an oil and/or gas problem? The bike only has 1900 miles (2002). Never had this problem before.
Old 05-27-2007   #2 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
Yeah, it's an oil problem--you used the wrong brand of oil. :-D
A little more serious: Leo, tell us a little more about your problem. Does the starter turn the motor over?
I suspect the clicking noises could be coming from the starter solenoid--especially if the motor is not turning over.
Check the battery connections first--make sure they are tight. I am assuming the emergency kill switch is in the run position or you wouldn't be getting any clicking noises. :-D Next, I would check other wires in the starter circuit for loose connections.
There are a few other things that can cause problems; however, I doubt if you would get the clicking noises: faulty side-stand switch and faulty neutral switch.
Good Luck,
Larry
Larry
Old 05-27-2007   #3 (permalink)
Favorite Bike: 1966 Bonnie
amanger's Avatar
I d be checking the battery.Sounds like its flat doesn t have enough power to kick the starter over.
07 865 Silver Bonnie....Bobbed Guards, Tacho, Grab Rail, Lucas Tail light, Mini Blinkers, Dart Screen, LSL Sport Bars, 1" Longer Hagons, 10mm Raised Forks, K&N Pods, Staintunes, 140/40 3 1/2 turns + 1 shim......etc....etc...
Old 05-28-2007   #4 (permalink)
bonnieblackinfl's Avatar
She's probably upset with you for calling her a 750, she's a 790, you know how women are about SIZE! :-D
Give her the extra credit for the additional 40cc's, you know that you would want it if it was you. :hihi:
bonnieblackinfl is offline   Reply With Quote
Old 05-28-2007   #5 (permalink)
GOZO's Avatar
If she's not turning over but clicking check your starter motor. I had a similar problem and put the battery on charge, put the battery back in and still wouldn't start. Put the bike in second gear, pushed it forward to turn the starter motor, put it back in neutral and no problem started straight away and been fine ever since.
GOZO is offline   Reply With Quote
Old 05-28-2007   #6 (permalink)
Before you start yanking parts off your bike...
Have you checked your fuses?
poop
Poor Man's AI removal
Bafflectomy
NH Rear sets
Rear fender - 'liminated!
Cafe bars and movie stars
Texas Tea
Rear tire needs air
Nathan is offline   Reply With Quote
Old 05-28-2007   #7 (permalink)
Leo
Obviously, I'm no mechanical genius! Thanks for the tips. Weak battery. I charged, it started!!! P.S. Rubbing the gas tank and apologizing to the old girl about the size of power plant probably helped.
Old 05-29-2007   #8 (permalink)
webonnielad's Avatar
I agree with Nathan.
Especially if she's got an alarm.
Any sort of open circuit, for instance a carb heater wire not attached will trip the fuse in the ignition circuit.
Believe you me I stripped half my lights off looking for a bad earth, to learn that one the hard way.
FUSES.
Jon (UK)
webonnielad is offline   Reply With Quote
73 bonnie 750 - kickstart malfunction roccotacco21 Twins Technical Talk 5 06-30-2007 06:40 AM
only firing on left side 76 Bonnie 750 Cram108 Classic, Vintage & Veteran 2 06-09-2007 04:40 PM
Bonnie won't start bonnienewbie Twins Technical Talk 13 12-03-2006 03:56 PM
HELP - Bonnie won't Start!!!! toocaffeinated Twins Technical Talk 14 11-09-2006 07:09 PM
Differences between speed triple 750 and trident 750 backwater T3 Sport / Touring Forum 7 07-12-2005 08:12 AM
