Motorcycle.com
Old 05-26-2007   #1 (permalink)
My wife has a new black Bonnie, but tends to both use and leave on the turn signals. Is there an after market product I can purchase and fit which will mod the turn signals on a 2007 Bonnie to self canceling? Thanks.
dryadsdad is offline   Reply With Quote
Old 05-26-2007   #2 (permalink)
Go to www.newbonneville.com & look under accessories. They have a turn signal flasher that is also a turn signal timer that turns them off. I haven't used one because for $100.00 I can turn them off myself. Bob.
357bob
Old 05-26-2007   #3 (permalink)
Thanks, Bob. I too think it rather silly but time after time she leaves them on. I'm concerned that falsely leaving them on is worse than not using them at all. -paul
Old 05-26-2007   #4 (permalink)
Favorite Bike: Triumph Bonneville (of course)
doctorjay's Avatar
This is one modification that time after time people have trouble with. I went with brighter L.E.D. lights and I can see them blinking even in bright sunlight. Also if you check Jenks Bolts...they have brighter lights and a loud annoying beeper that stays on if and when the turn signal is on (had it, and removed it)
TOR's, AI removal, Polaris bellmouth, K&N air filter, 118 jets, Hagon progressive fork springs, sissy bar, summer wind screen, union jack brake resevoir
doctorjay is offline   Reply With Quote
Old 05-26-2007   #5 (permalink)
I'd have no idea how to locate brighter LED's. I may try that loud noise, however. To me, this is a silly issue. I mean, if she left them on once or twice, fine, but time after time? I don't understand what her problem is, but I feel I need to address it.
Old 05-26-2007   #6 (permalink)
Favorite Bike: 2006 Thruxton "Zoe"
mr_badda_bing's Avatar
I think it is just a matter of giving her time to figure out that she needs to turn them off. I did the same thing the first few times I rode after not having a bike for a length of time.
Gently remind her when she leaves them on. A quick pop in the back of the head with an open palm usually suffices
2006 Thruxton - Zoe Yellowbike
125 main jets, 42 pilots, 1 shims, 2 turns, HARK (homemade airbox removal kit) EMGO Reverse Cones, 17T sprocket. 4700 Feet Above Sea Level
mr_badda_bing is online now   Reply With Quote
Old 05-26-2007   #7 (permalink)
I'll give it a bit more time, but she's got about 700 miles on the Bonnie with this persistent problem. When I note she's not turning them off, I catch up to her with the Tiger and give a sign.
No, not THAT sign!
Old 05-27-2007   #8 (permalink)
The product refered to that is sold by Newbonneville.com is the Signal Minder and is a simple plug and play device that replaces the turn signal module. It has three different time out intervals.
However, with a bit more work the device can be used to turn you signals into running lights that are always on and then blink when the turn signal is activated. It takes a bit of wiring (supplied), a mod to the turn indicator on the instrument cluster and a bit of work. I'm really pleased with the increased conspicuity at night.
merlin is offline   Reply With Quote
Old 05-27-2007   #9 (permalink)
do you forget to flush? or open a door before you walk thru it?
riding should be practiced till its 2nd nature to do the correct thing, some people only get a chance to make 1 mistake, others are more lucky. Whats so hard about hitting the darn cancel button?
G
I just wanted to ride
Old 05-27-2007   #10 (permalink)
I have no desire to add more silly lights to a bike. If I could, I'd turn my headlight and tail light off. I also think using signals on a bike silly. I use hand signals only which never fail to turn off.
However my wife prefers electronic signals and this thread is about her despite the rather nasty add to this thread right below your post.
I will get the device at NewBonneville if the problem persists. It costs $100 but I've already experienced $101 worth of annoyance having to watch these signals flash on and on for many miles.
turn signals otagohighlander T3 Sport / Touring Forum 4 12-18-2007 01:37 PM
turn signals akenaten Modifications & Workshop Talk 5 01-28-2007 10:00 AM
Sef cancelling turn indicators from the legend RJScotti Hinckley Classic Triples 3 10-23-2006 11:04 PM
turn signals pendraig Classic, Vintage & Veteran 11 06-30-2006 01:45 AM
self-cancelling turn signals paulie Tiger Chat 19 07-26-2004 12:40 PM
