BikeBanditShopTriumph.comTrident-Exhausts.comMotorcycle.comTriumphPerformanceUSACycleGear.comSportbikeTrackGearbritishcustomsMotorcycle.com Classifieds!Annitori DistributingRacerPartsWholesale
Old 05-25-2007   #1 (permalink)
Favorite Bike: '07 Black
Other Motorcycle: whatever.
Extra Motorcycle: nope.
Anyone know if a Pit Bull (or comparable brand/product) works on Bonnies? Anyone use one? Thanks.
rdromano is offline   Reply With Quote
Old 05-25-2007   #2 (permalink)
Favorite Bike: Triumph Speed Triple
Blindboypig's Avatar
Other Motorcycle: Aprilia Falco (silver)
Extra Motorcycle: Aprilia Falco (red)
We use the Pitbull SS rear stand on our Thruxton and my Thunderbird - great stand - should work with anything from a '71 Honda CB350 to an '07 ZX10R. :chug:
[ This message was edited by: Blindboypig on 2007-05-25 21:17 ]
Ride Safe
Blindboypig is offline   Reply With Quote
Old 05-26-2007   #3 (permalink)
Simmons's Avatar
Pit Bull stands do not work with Bonnevilles that have stock exhaust. The pipes block the stand from catching the nut to lift the back of the bike.
Found that out after I bought the stand. :-D
hope this helps,
Simmons
'04 Bonneville Black: Progressive fork springs, Ikon rear suspension, mini speedo with D9 bracket, Lucas style tail light, clip-ons, and a few other little mods.
Simmons is offline   Reply With Quote
Old 05-26-2007   #4 (permalink)
So for ease of chain cleaning, etc., I'm stuck with ordering the Triumph center stand?
Old 05-26-2007   #5 (permalink)
I sold a Lockhart Phillips stand today for a Bonnie - it had the flat swingarm lifters instead of the v shaped bobbin lifters - costs 100 and is really easy to use. It is a little heavier than their aluminum stand, but is $50 less and works just as well. Highly recommended.
Perkey1 is offline   Reply With Quote
Old 05-26-2007   #6 (permalink)
Scot03Bonnie's Avatar
A Pit Bull rear stand will work with stock Bonnie exhaust, you just have to get the end fitments that are adjustable dual purpose, spool forks on one side or you flip it over and it has rubber covered tabs that ride under the swing arm, forward of the axle nut. These adjust in or out to fit inside the muffler cans.
I think there are also tab-only ends available, but I bought the convertible type because my ZX9 has spools. Any dealer that sells Pit Bull should have a list of these accessories and order for you.
A rear pit stand works great for changing oil and adjusting the chain, not quite so well for rear wheel removal, but if you do use it for that, you can't have the axle nut resting on the stand, which is another reason to get the tab-type ends. I use a bike/atv lift for wheel removal, so much easier to get the height positioned lust right when re-assembling.
[ This message was edited by: Scot03Bonnie on 2007-05-26 00:19 ]
Scott- ATL
Scot03Bonnie is offline   Reply With Quote
Pit Bull front stand - OK to use on my Tiger? Soupamoto Tiger Workshop 2 01-04-2008 05:14 PM
Can the Pit Bull Stand Be Used With the TBA? Tiglath Twins Technical Talk 6 10-09-2007 05:45 PM
PIT BULL STAND 2002SPEEDTRIPLE Speed Triple Forum 3 01-18-2007 08:52 AM
Pit Bull stand KarmaPunk1 Speed Triple Forum 2 10-17-2006 08:08 PM
Pit Bull rear stand pin Azvtx Speed Triple Forum 12 03-17-2006 10:16 PM
