» Links |
05-24-2007
Supersport 600 Favorite Bike: MINE OF COURSE!
Posts: 151 Other Motorcycle: 2005 KTM 450 Extra Motorcycle: Coletta 6'2" pintail
Gathering info on my Thrux project. Looking at a setup that consists for:
1000 feet to sea level
Open Exhaust (Predators)
Air Box hacked with K&N's
Air Injection pulled
Jenks Suggestions for the Thruxton with the mods as stated above:
Mains = 140
Pilots = 40 (stock)
Needle Shim = 1 (where do I get one?)
Needle = NBTZ
Pilot Screw = 2.5 turns (stock)
Airhole on slide opened up to 3mm from 2.5mm
Now... Jenks has a NBZT as the STOCK needle... and has a NBTZ as the suggested needle. Anyone know if this is just a typo? (Page 10 of the Jenk's manual)
Thanks!
Never settle for the usual.
'05 865 Thrux-ton - Super-Duper Modified: painted inner tube caps yellow, purple tassels on the bars, and pink neon lighting.
Formula Extreme Favorite Bike: 02 Bonneville
Posts: 558 Other Motorcycle: 05 SV650S
NBTZ is the stock needle used in the 865's. Also called Thruxton needles... don't think its a typo
02 Bonneville - Originally green/silver , now going black. Dual headlights/black fly screen. Emgo Shortys, rubber bellmouth, Uni, AI, 120/42, thrux needles, no shims. Thruxton seat and low bars. Ikon 7614 shocks, renntec rack. A Bonnie Cafetourer..
05-24-2007
Formula Extreme Favorite Bike: 05 T100
Posts: 634 Other Motorcycle: Don't need another one!
No, No, No. The "Thruxton" needle, also fitted to the 865cc T100, is the NBZT. Look at the Triumph workshop manual and the Haynes book. NBTZ IS a typo in Jenks' doco. Perhaps someone should tell him, perhaps I will.
Paul.
Herts. UK
Opal & Tangerine 05 T100 (865cc)
(Previously Ducati Monster S4 and numerous UJMs)
05-24-2007
ahh, doh! didn't see that it was TZ/ZT, thought it was the same :chug:
05-24-2007
Moto Grand Prix Favorite Bike: '03 T-100 & '07Tiger1050
ivar,
I thought you were applying for an editorial job at P. Jenks. :-D
Larry
Larry
05-25-2007
I've messed with a few bikes and their carb needles, and slight taper differences are sometimes separated in the similar manner. (letters or numbers) Yes, TZ vs ZT typo can cause a little confusion. Thanks guys.
[ This message was edited by: unitedrocker on 2007-05-25 08:08 ]
05-25-2007
In case anyone's interested, I had a dialog today with Jenks about another issue and asked him about the discrepancies in his tuning guide regarding needle names. He confirmed that "NBTZ" is a typo and should read NBZT. He is going to correct this and put a new version up on his site in the near future.
Paul.
Herts. UK
