britishcustomsAdvanstarMotorcycleShowsShopTriumph.comSpringfield ArmoryCycleGear.comSportbikeTrackGearMotorcycle.comRacerPartsWholesaleTrident-Exhausts.comAnnitori Distributing
CycleGear.com
Old 05-24-2007   #1 (permalink)
Got the bike dynoed, sorry I dont have the technology to post a picture, but she put out 60 rwhp, 49 ft/lb torque, and a nearly perfect A/F of 13 across the whole rev band, and at steady state. The graph has a theoretical perfect red line, my line is blue, and it follows the red line so close they appear to be 1 purple line.
Frank, at Sun Cycle, was impressed.
I can recommend their dyno, and they appear to be a pretty good full service shop as well.
G.
40/140 jets with 1 shim on a thrux needle, 3.25 turns out on pilot screw, sprint mufflers, uni pods.
thanks Jenks
I just wanted to ride
Old 05-24-2007   #2 (permalink)
Favorite Bike: Black Bonnie
On my old 790 i had airbox removed and predators. I was running 1 shim 45's and 145's. Never had it dyno'd but it ran well. Better do my homework before I start modding my new 865. Seems to be quite a difference with the thrux needles.
-Aaron
Colonel_Dorkus is offline   Reply With Quote
Old 05-24-2007   #3 (permalink)
Congratulations on the dial-in, Geoff.
Does this mean you are thru with engine
perormance mods? :-D
2112 is offline   Reply With Quote
Old 05-24-2007   #4 (permalink)
Cant go any farther without spending more dough...so I have to leave it alone
G
Old 05-24-2007   #5 (permalink)
Here's my 790, no air box with D&D's.. Running 42 pilots thrux needles and 150 mains.. The dyno run was done at 2000ft so at sea level it might make more.. As you can see at the end of the RPM it gets crazy so I think it's on the rich side..
1409 is offline   Reply With Quote
Old 05-25-2007   #6 (permalink)
Favorite Bike: My Bonneville of course
04BBonnie, Did they chart your AF ratio? You seem to be making great HP with that motor, if you bought a Procom High Rev ignitor you would be pleased. If your patient you can find em new on Ebay for $100.
Geof, Awesome to know you got it right! UNtil the nextmod of course......never ending!
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 05-25-2007   #7 (permalink)
Vert,
No AF chart.. I'll have to go to a local dyno and see what I come up with.. I have a Thrux rev box that I might try and exhaust cam... I guess she runs good for a 790 with no air box and D&D's..
The only other thing I did was port match the intake manifolds to the head.. The stock manifold are quite small compared to the ports in the head..
Old 05-25-2007   #8 (permalink)
wow , you are making some good power. It looks like you might get even a tad more if you get that top end figured out perfectly.
Mine was making more power as it climbed, but Frank was hesitant to bounce it off the rev limiter, so we called it quits at about 6800 rpms
G
Dyno results oil-spitn-rat Hinckley Classic Triples 6 02-10-2008 01:24 PM
dyno results trumpete The Rocket Science Forum 4 11-18-2007 12:16 AM
Dyno Results. Silver Streak Sprint Forum 0 10-03-2007 09:40 AM
Dyno Results - Stock 06 S3 fire911 Speed Triple Forum 24 09-06-2007 08:39 PM
Dyno Results TrackerOldGuy Speed Triple Forum 17 08-18-2006 07:08 PM
