britishcustomsAdvanstarMotorcycleShowsShopTriumph.comSpringfield ArmoryCycleGear.comSportbikeTrackGearMotorcycle.comRacerPartsWholesaleTrident-Exhausts.comAnnitori Distributing
CycleGear.com
Old 05-22-2007   #1 (permalink)
Favorite Bike: 2004 Triumph Bonneville
peter_s's Avatar
Other Motorcycle: I want a street triple
I am wondering how motorcyclists know when their tank is close to empty? Do you just wait for it to hit the reserve?
I currently have set the trip meter to 0 on a full tank and will wait and see when it hits reserve. Currently I am at 168KM. Is this a good enough method? I am asking because as a new rider, I have a lot on my plate, I find I am at full concentration most of the time I am on the bike and for me to be in the middle of a turn and the engine cuts out, requiring me to reach down and fumble for the fuel switch to turn on reserve would be adding uneccesery stress.
So, topping up at X number kilometers would be my best bet as long as I can figure out what X should be.
I was told by the dealer (a honda dealer, the bonnie was a trade-in) that I should add a "stabilizer" to my fuel, what is that? My HD riding buddies tell me to just use high octane premium fuel, the expensive stuff at the pumps.
Any thoughts?
peter.
share what you know....learn what you dont.
gnu.org
debian.org
peter_s is offline   Reply With Quote
Old 05-22-2007   #2 (permalink)
That's pretty much what we all do - zero out the odometer and use it as your gas gauge. You'll hit reserve somewhere between 220 and 250km, depending on your particular bike and riding style. And skip the stabilizer unless you will not be riding for a while or you are storing the bike for the season - I've found my bike runs poorly with the additive. You can find it at any Canadian Tire. Just stick to the mid- to high-octane fuel and you'll be fine.
Welcome, Peter!
KingBear is offline   Reply With Quote
Old 05-22-2007   #3 (permalink)
Loxpump's Avatar
I burn the high octane stuff myself. 93 octane I think, about $3.57 a gallon around here, too much to burn it in my cages. I also zero out my trip gauge and at 100 miles of so I try to fill her up, but have gone 120 and not had to hit reserve. Also I never use any of the stabilizers even in the winter, I get out and run her all year even if it's 20 degs. Gas can sit a fews weeks or so without going bad. I have never had a problem, even in my truck that routinely sits for weeks without getting started. In the winter I may put in a little Heet in the tank, which is just alcohol that mixes with any moisture in the gas so it gets gets burned up with the fuel.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 05-23-2007   #4 (permalink)
Favorite Bike: 2006 Bonnie Black
It's a good idea to get to reserve a few times, so you know how far you can go (make sure you're in an area with service stations though!). As a rule, I try to fill up every 100miles, as this also forces me to take a break. However, I usually get to reserve at about 145miles (was 135 once!). I've gone upto about 165miles including reserve.
Ride safe.
Zaq in NZ
zaqtronic is offline   Reply With Quote
Old 05-23-2007   #5 (permalink)
Favorite Bike: '06 T100
That wouldn't happen to be an '04 T100 would it. I might know the bike. A guy I know just traded his in on a Honda ST1300. Good Bike.
You shouldn't hit reserve on that till around 240 km, your trip meter is your fuel gauge. Try and stick to 89 octane or higher.
Rick
Some people are a lot like Slinkys.
Not really good for anything, but bring a smile to your face when you push them down the stairs.
Big_Rick is offline   Reply With Quote
Old 05-23-2007   #6 (permalink)
Dont be afraid to hit reserve, thats what its for. The bike will only cough once then keep going, to tell you its time for reserve. Once you do it a couple of times, you wont fumble it
G
I just wanted to ride
Old 05-23-2007   #7 (permalink)
I have found that my Bonne runs the best on the highest octane available, I think it is 97 octane. I always try for BP fuel in Australia, it seems to be the most trusted. Your confidence will grow, don't sweat the small stuff. One thing you coul do until you gain ability is to top up with fuel each time you go out.
Black is the new black
ntr1972 is offline   Reply With Quote
Old 05-23-2007   #8 (permalink)
Favorite Bike: My Bonnie
Other Motorcycle: My other Bonnie
Extra Motorcycle: '98 FXD
All good advice...just fill up at 90 or 100 miles for awhile till your confidence builds. (DO exercise your petcock regularly, however)
I'll start using a stabilizer in the late fall...I DON'T use STABIL...there are better products out there (Briggs supreme or one of the marine products) ...follow directions...most people use too much.
As far as "heet" goes...if you use it...run it THROUGH to eliminate the moisture...you don't want a bike stored with the water/alcohol mix sitting in the tank and fuel system.
...Billy
Shoot safe, straight and often...
BILLYSIM is offline   Reply With Quote
Old 05-23-2007   #9 (permalink)
Favorite Bike: 2007 Bonneville Goodwood Green
I get approximately 40 mpg, and I use the trip odometer as my fuel gauge.
Only hit reserve once, and yes, it's a good idea to exercise it first so you don't fumble trying to get reserve turned on. . .
I use 89 octane fuel and my Bonnie runs great.
ride on
rick
live to ride
rick05rocket is offline   Reply With Quote
Old 05-23-2007   #10 (permalink)
Favorite Bike: Scrambler
panthercity's Avatar
Other Motorcycle: R1150RSA
Extra Motorcycle: R1100RSA
Avg 44mpg on mid-grade (89 octane R+M) and 48mpg on regular (87 octane R+M).
Tests conducted over four tanks of each.
Bob AMA #162726 LPR #54
`02 BMW R1150RSA
`06 Triumph "Scrambled"
panthercity is offline   Reply With Quote
Newbie Questions NewOldSkool Twins Technical Talk 7 06-10-2007 07:12 AM
More questions from the newbie Butcher Twins Technical Talk 7 02-10-2007 10:43 PM
More Newbie Questions Scouser Twins Technical Talk 3 08-12-2006 07:35 PM
newbie with some questions grunt11b40x Speed Triple Forum 8 10-31-2005 11:31 PM
Newbie w/ Fuel Questions?? Edelin Twins Talk 18 10-07-2005 02:08 PM
