i know that doesnt mean much - - but if i could lay out some observations / symptoms, i sure would appreciate any advise you guys could offer.
Bike: 06 Bonnie 790, Staintune Reverse Cones, jetting unknown (got the dealer to fit cans and they assure me they fit the jets that Staintune recommend - but they now cant tell me what the exact ones are)
Recent Service (10thou klm): Bike was running lean. Mechanic put a shim under the stock needle
Observation: Bike pulled harder from low to mid range (from richer mix I guess), easier to start, + sat on 120-140km/hr much easier (less throttle twist), purred along.
Recent Observations: last 1000km (in about a week and a half) including some vigorous twisty action on weekend - Popping worse than before. Still starts easier than before service, but vibes in bars worse. Increase in heat from engine (marginal) BUT the biggest thing ive noticed is that acceleration and sitting on any speed above 80km/hr or so is requiring significantly more throttle action/work. Seems to need to be worked harder to achieve same accel as just after the service. The only different thing was that i put a tank of 95RON petrol/gas instead of the dealer recommended 98RON about 2 tanks ago + it recieved a bit of a flogging in the twisties on the weekend.
When running at speed/revs, taking throtle off altogether = engine braking/fork dive.
Questions
1. Is this just a sign that things are lean again
2. Was the shim a good idea just to fix mixture ratio
3. Should i just adjust mixture.
4. Would the mixture go 'out' that quick/easy
sorry for length of post, but any comments or advice would be greatly appreciated guys. bike still a blast though - love the bonnie in an almost unnatural way!!!
