Tried again today, kicked it over a lot without the sparks and after a while fired it up again with the same result
The oil is coming out of the airbox breather and the suction from the carb makes loads of oil come out.
I tried draining the oil out of the bike and then kicking it over again without the plugs in to try and clear it.
Anyway the bike fires up easily enough (for a trumpet :razz: ) and I ran it with the airbox off and a tube connected from the breather to a catch bottle. There doesn't seem to be anysign of the oil drying up?? Seeing as there is only about a litre of oil in the bike anyway I can only assume there is an internal leak, Could this be the oil pump?
The bike has only done 8000 miles before it was laid up so I can't see it being a major mechanical fault.
Cheers
Mark
