SportbikeTrackGearCycleGear.combritishcustomsShopTriumph.comAnnitori DistributingSpringfield ArmoryTriumphPerformanceUSAMotorcycle.com Classifieds!RacerPartsWholesaleAdvanstarMotorcycleShows
Old 05-20-2007   #1 (permalink)
I've been riding around without my rego label (not the number plate) because there is nowhere I can find to put it. Must be on the left hand side according to the LAW.
Any ideas?
[ This message was edited by: ntr1972 on 2007-05-20 06:38 ]
Black is the new black
ntr1972 is offline   Reply With Quote
Old 05-20-2007   #2 (permalink)
mlc
mlc's Avatar
if its in a hard plastic sleeve with a hole one side - it will bolt onto the inside of the pillion footpeg bolt (left side). gotta unbolt to change it which is a pain the ar se, but its only once a year.
although im trying to track down one of these locally to attach the plastic sleeve (which i dont mind) onto the rear frame
from MikesXS site
[ This message was edited by: mlc on 2007-05-20 06:52 ]
mlc is offline   Reply With Quote
Old 05-20-2007   #3 (permalink)
Favorite Bike: 07 Bonnie Black
Other Motorcycle: 1989 GPZ Kawaski 900
I put mine in a circular plastic holder, screwed it to the left side of the number plate and then pushed it behind the plate.
It is there, but out of sight.
smac is offline   Reply With Quote
Old 05-20-2007   #4 (permalink)
To the rear of left side cover between shock and frame,there is a small plastic inner mudguard that you can drill to mount the rego lable holder to.Able to seen but barely noticeable cheers.
straycat is offline   Reply With Quote
Old 05-20-2007   #5 (permalink)
What exactly is a rego sticky label? :???:
beagldog is offline   Reply With Quote
Old 05-20-2007   #6 (permalink)
its a sticky backed label 4"x 3" aprox with bikes particules on it,[ vin,cap,colour,date of exp ect] different colours for every year makes it easy to id unregersted or stolen vehicles
Old 05-21-2007   #7 (permalink)
G'day mate
Stick it into a plastic universal holder then have a look between the left side cover(rear) and the frame tube.you will see a air box screw,thats where it will go.Sideways but a good spot well out of the way,and legal(I think)
Macca.
Maccaoz is offline   Reply With Quote
Old 05-21-2007   #8 (permalink)
Thanks fellas.
Old 05-21-2007   #9 (permalink)
In W.A. (aus) the rego sticker is approx 7cm circle. Easier to hide behind the license plate.
Old 06-02-2007   #10 (permalink)
I have been using a rego label tube on my bikes for some time now. You can see it is that that blue thing just above the pipe. Before you ask yes it's legal - How do I know- Well lets say it has been roadtested by the local law!
The inner tube part rotates so you can check the whole label.
It is always fairly easy to find a place to mount it as it doesn't take up much room- there is also a version with an LED light inside...
I got this one from austreetfighter.com.au. but you can get cheaper all plastic versions from bike stores for around $14
Blackjacks '07 T100
  • Raask Minizoom Rak Straight
  • NARK
  • AI Removed
  • Procom ignitor
  • Thruxton Front Guard
  • D9 Layflat
  • CRS Carbs - 120 main, 60 Pilot, 2 Turns, 2 down on Needle Clip (7 Clip Needle), 14mm Float height
  • + Other assorted bits and pieces
Blackjack is offline   Reply With Quote
How do you put a sticky message on your threads galesa2 Sprint Forum 3 09-18-2007 09:00 AM
Someone needs to put a warning label on the saddle bags for the 06 sprint.. stinky93071 Sprint Forum 35 11-30-2006 07:54 PM
This story put me in my place! ohiorider Twins Talk 11 11-11-2006 12:27 AM
Where do you put your rego sticker? Wildcard Sprint Forum 7 10-24-2006 10:19 AM
rego label mount? IceT The Rocket Science Forum 3 04-21-2006 08:05 AM
