I would check out the jetting for sure and see if it matches what you need. Who knows what you have in there. If your plugs are fouling that bad it sure sounds like it is running rich. Also make sure your air cleaner isn't clogged and your choke is opening all the way. That's the easiest things to check first and it doesn't cost anything.
Stop Global Whining!
Semper Fi!
