Wire it directly to the battery with a switch of some sort (such as a toggle switch) for you to use when you want it powered up. I have satellite radio and did the same thing. Put the toggle by the other accessory lights on the tank. Works great. I have it on a disconnecting line so that when removing the tank it easily disconnects.
Roadster screen, TOR pipes, AI removed, rejetted, light bar on front, dually pegs, iso grips, kuryakyn mirrors, all chromed out, tach, triumph bags, tank bag, short sissy bar w/luggage rack, corbin saddle, sirius satelite radio........
