RacerPartsWholesaleCycleGear.comMotorcycle.comBikeBanditTriumphPerformanceUSAAdvanstarMotorcycleShowsSpringfield ArmoryMotorcycle.com Classifieds!ShopTriumph.com
SportbikeTrackGear
Old 05-16-2007   #1 (permalink)
Favorite Bike: '04 Speedmaster
TOMKRILL's Avatar
Other Motorcycle: I'd love an old Vincent
Is there a replacement chain for a Speedmaster that is much better than the OEM that comes with the bike from the factory?
"The most happy marriage I can picture or imagine to myself would be the union of a deaf man to a knock out blind woman who digs motorcycles."
TOMKRILL is offline   Reply With Quote
Old 05-16-2007   #2 (permalink)
I tried to find the same thing when i replaced mine. From what i gathered the stock chain which is a DID X-ring is supposedly as good as it gets. There is one other that shows it's strength rating as higher, but what i read was that that is not a true indicator of real life quality. Anyways, if i recall it was made by RK. Not sure tho.
Old 05-16-2007   #3 (permalink)
Favorite Bike: 05 Black Speedmaster
What problems are you having with the stock chain ?
Old 05-16-2007   #4 (permalink)
TOMKRILL's Avatar
No problems at all.
Old 05-17-2007   #5 (permalink)
Is your chain about shot? Are you adjusting it a lot? My first one lasted I believe 17,000 miles.I've talked to others that got more.Compared to years ago this is really good. I use to have to adjust my old chains every week.I think I went like six months on this bike before adjusting it,and I do ride it to work six days aweek most the time.I guess you could fork out the bucks and get the belt drive set up if you don't want the hassle of the chain. :hammer:
speedblue is offline   Reply With Quote
Old 05-17-2007   #6 (permalink)
I got a gold chain from newspeedmaster.com It is a DID chain. I used a clip masterlink and remove the chain to clean and lube it. I have found that soaking the chain in motor oil will keep the chain both wet and clean for a long time. Regular chain lube is too sticky and I believe it causes more harm than good.
HOG= Harley OWNER group
RAT= RIDER Association of Triumph
Matt_the_Rat is offline   Reply With Quote
Chains jlbonnie2000 T3 Sport / Touring Forum 4 06-11-2007 01:33 PM
more on chains dangrass Sprint Forum 1 10-11-2005 02:38 PM
Gearing and Chains LegendTT99 Hinckley Classic Triples 13 10-11-2005 12:03 PM
Chains Unsane Sprint Forum 4 04-27-2005 03:30 PM
Drive chains j98sprint T3 Sport / Touring Forum 8 02-24-2003 06:48 AM
