Annitori DistributingBikeBanditCycleGear.comSpringfield ArmoryShopTriumph.comRacerPartsWholesaleMotorcycle.com Classifieds!Motorcycle.combritishcustoms
CycleGear.com
Old 05-15-2007   #1 (permalink)
Favorite Bike: MINE OF COURSE!
unitedrocker's Avatar
Other Motorcycle: 2005 KTM 450
Extra Motorcycle: Coletta 6'2" pintail
Bonneville vs Thruxton Mufflers - Dumb question I'm sure, but are they straight swaps? Meaning can you install a set of Bonnie aftermarkets onto a Thrux?
Thanks!
Never settle for the usual.
'05 865 Thrux-ton - Super-Duper Modified: painted inner tube caps yellow, purple tassels on the bars, and pink neon lighting.
unitedrocker is offline   Reply With Quote
Old 05-16-2007   #2 (permalink)
Man... 43 views and no answer... is it THAT bad of a question? :razz:
Old 05-16-2007   #3 (permalink)
Not a bad question,just a tough one. Some people here have installed Thrux cans on Bonnie pipes with a little effort. Some people can`t get them to work at all. I have Thrux cans on my bike,but don`t have any factory mounting points to hinder me. If you are persistant and creative,anything can be made to fit anything.I know,no help at all.
Old 05-16-2007   #4 (permalink)
I put an entire thrux system on my T100 with no issues, you maybe able to run the mufflers with one of the adapters such as bella corse sells. The BUB system will work on either bike - thats pipes and mufflers.
http://www.triumphrat.net/memberalbums/data/500/thumbs/dragon1.jpg
John W.
  • 04 Thruxton – Graphite & Opal
  • 06 T100 – Black & Red
  • 05 T100 - Black & Opal - Project Bike
  • 51 T100 – Silver & Black
Thrux-ton-up is offline   Reply With Quote
Old 05-16-2007   #5 (permalink)
Favorite Bike: My Bonneville of course
As I understand it the issue is that the kink in the header is different between the Thrux and Bonnie. So if you bought a Bonnie slipon and slippedit on your Thrux the mounting tab would not line up to your passenger peg bolt. If you found a cheap set of Bonnie cans you could perhaps fab a bracket to makeit work.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 05-16-2007   #6 (permalink)
bonnieblackinfl's Avatar
I done it, no problems.
bonnieblackinfl is offline   Reply With Quote
Old 05-16-2007   #7 (permalink)
Great info, thanks!
I just didn't know if it was a major issue with the header bends or a simple bracket issue. Fabbing brackets are no problem, but buying a set of headers is.
THANKS!
Will the Thruxton mufflers fit on a Bonneville? lsettle Twins Technical Talk 2 06-15-2007 03:35 PM
Thruxton mufflers on a Bonneville-lots of questions Motoleo Twins Technical Talk 14 09-15-2006 09:51 PM
Thruxton Mufflers jkieler Twins Technical Talk 0 09-07-2006 09:27 AM
bonneville mufflers and centerstand gmbigsby Twins Talk 11 01-20-2006 02:00 PM
Thruxton Mufflers on a Tbird? Tbird95 Hinckley Classic Triples 4 05-16-2005 10:43 PM
