True +1, only engine I EVER want to sound as quiet as a stock Bonneville is a generator. Without pipes you will hear every valve open and close, the slightest piston slap will convince you your rods are about to poke through the case and the clutch chatter will seem to get louder and louder as you listen more attentively. Cure = pipes. It is a motorcycle after all.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
