Front brake replacement / any thoughts - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda Powersports
Old 05-13-2007, 04:42 PM   #1 (permalink)
Favourite Bike: 2003 Triumph Speedmaster (Red/Blk)
Pauley's Avatar
greetings,
I'm gonna attempt putting on new pads in the front. I think I can wing it. Are there any suggestions from people who have already done this?
Thanks
Pauley
Hey Benefits Lady, Can I retire now??
Pauley is offline   Reply With Quote
Old 05-13-2007, 06:13 PM   #2 (permalink)
Other Motorcycle: 66 Bonnie Chop
Pretty straightforward brake work. Here's Pat's how-to on the rear pads, bit of a reference.
Pat's Rear Brake Write-Up
Al
ssjones is offline   Reply With Quote
Old 05-13-2007, 08:06 PM   #3 (permalink)
Favourite Bike: 05 Black Speedmaster
Make sure the springs are seated properly so they don't rub on the rotor.
Old 05-15-2007, 12:31 AM   #4 (permalink)
Its an easy enough job. The only hint I can think of off hand other than the correct position of the springs is to use some anti-sieze lube on the reatining pins. A little goes a long way just don't over do it
"Anyone who stops learning is old, wheter at twenty or eighty. Anyone who keeps learning stays young, the greatest thing in life is to keep your mind young."
Henry Ford
"You may say that I'm a dreamer, but I'm not the only one"
John Lennon
Imagine
britironrider is offline   Reply With Quote
tips/tricks for front brake replacement? Orpheus Twins Technical Talk 9 02-01-2008 04:32 PM
T140 replacement front brake lever/cylinder yellowtrumpet Club Cafe' 6 11-07-2006 01:19 PM
Front Brake Pad Replacement T100Aust Twins Technical Talk 8 09-04-2006 07:30 PM
front brake pad replacement - how frequent? whoa Club Cafe' 2 05-14-2006 09:04 AM
Your thoughts on replacement tires for Bonnevilles evedave Twins Talk 8 03-24-2006 10:31 AM
