loose turn signal - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 05-12-2007, 06:42 PM   #1 (permalink)
Favourite Bike: 1970 T120R(unrestored)
Other Motorcycle: 2002 Bonneville
Extra Motorcycle: 1970 T120R(restored)
I have a rear turn signal that is loose. According to the manual you have to take out the rear fender and remove the rear light mounting bracket to access the nut that fastens the turn signal to the bracket.
I would appreciate any suggestions to make it easier.
Thanks in advance.
Just music and my motorcycles. Thats all I need.
retrobiker is offline   Reply With Quote
Old 05-12-2007, 07:26 PM   #2 (permalink)
TCL
Favourite Bike: Triumph Bonneville T-100
TCL's Avatar
Other Motorcycle: 1977 Honda CB400F
I would definitely remove the fender. It only takes 4 bolts. The tail light has 3 bolts that go through grommets in the fender. These required a considerate amount of tugging to get out when I took my light off. It's pretty plug and play from there. All you'll have to do is give the signal nut a turn or two and put it all back on. Do this all with the fender on a good solid workbench, not a stool, or you risk dropping the fender trying to yank the light off.
Death or Glory
TCL is offline   Reply With Quote
Old 05-12-2007, 07:45 PM   #3 (permalink)
Thanks TCL.
Will the wiring harness present a problem? There is only so much length to work with.
Old 05-12-2007, 08:37 PM   #4 (permalink)
I think if mine sags any more , I will replace them w/ rigid stalks from Kirk or someone. @ $14 it will be worth not having to do it again! Did the fronts already- they look great!
Besides the plastic chrome isnt holding up too well anyway. :hammer:
CAPT D
Old 05-12-2007, 10:13 PM   #5 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
Retrobiker, are you sure that it's loose? They "naturally" have some slop in them.
The fender is easy to remove, but be careful to avoid scratching it. There's a wiring connector for it under the seat, trace the rear wires to identify it.
Marty
Old 05-13-2007, 12:12 AM   #6 (permalink)
The nut was loose and that side was almost dangling. I was only able to hand tighten it. I'll remove the fender as you folks have suggested.I'll look for that connector. Thanks for the suggestions.
Probably will have to eventually replace them too if it keeps coming loose.
Old 05-13-2007, 07:01 AM   #7 (permalink)
Favourite Bike: Modified 2005 T100
Other Motorcycle: 1994 CB750
Id say if it is stock replace it with something a bit less cheap and plastic looking :-D
Every sunday is mad sunday.......
BeastInBlack is offline   Reply With Quote
Old 05-13-2007, 09:46 AM   #8 (permalink)
Got her done. It was a pain to get the fender and tail light off just to tighten one nut. The connector sits right on top of the fender.The rigid type of stalk seems like a good option if this happens again. I looked up Dennis Kirk but am a little lost as to which make and type.I'll keep looking.Hopefully it doesn't need replaced for a while.This platic stuff is pretty flimsy but keeps the overall cost low I guess.
Thanks again.
Old 05-13-2007, 08:18 PM   #9 (permalink)
Favourite Bike: Thruxton
Retro,
There is a modification, shown with clear photos, that shortens the stalk and makes the lights look better for ZERO money. Shorter stalks, it seems would hold up better.
Check it out.
davidc is offline   Reply With Quote
Old 05-13-2007, 10:38 PM   #10 (permalink)
Thanks,davidc.Could you please help me locate that post?Can't seem to find it.
Turn Signal Daytona Deliberations 4 10-11-2010 02:35 PM
Turn Signal Connector CoburnAndHughes Twins Technical Talk 4 10-20-2007 12:20 AM
Right turn signal out raff Twins Technical Talk 10 05-25-2007 10:33 AM
turn signal? Jacksmack77 Twins Technical Talk 1 04-13-2007 03:23 PM
Turn signal relay pineygroveshop Tiger Mods & Bolt-Ons (archive) 2 11-28-2005 04:47 PM
