On 2007-05-10 22:55, UlyssesCale wrote:
....I bought the bike with the Airbox Eliminator kit installed (Isn't that illegal in CA for the dealer to do this to a new bike?) and the British Racing pipes in stead of the stock ones.
Yes. Patently illegal for a paid mechanic to disable any of the CARB-mandated smog equipment. If worse comes to worse, you could use this to force the dealership to restore your bike to stock, then take it elsewhere for decent service/tuning.
1) Awful awful awful gas mileage. Just the worst I would ever expect. People are telling me it will get better as the bike sets itself up through the break-in.
What do you consider awful? The bike should improve a bit as you break it in. That being said, my '04 Bonnie (with all of 1200 miles on the clock) returns 38 mpg ridden hard on back roads (stock but for TOR exhaust canisters and 115 main jets). Crusing at 55-65 mph returns 42 mpg.
2) The little vacuum(?) nipples on the carburetor blow off when the bike pops and backfires. The nipples I am refering to are in between the carb body and the cylinder ans stick up from the intake manifold. The nipples are covered with little rubber caps. These caps fly off the bike when I start the bike. I rode 30 miles on the highway with one of them off the bike (I didn't know it fell off! I have to assume the bike is just set up so ***** lean or improperly jetted leading to the popping and backfiring. Do I need to worry about the rubber cap coming off and then riding it on the highway? I only realized the cap was off because the bike started to die at lights.
If the bike is backfiring hard enough to blow off the rubber caps on the vacuum ports, something is wrong. Did your dealer re-jet your carbs for those non-stock mufflers and airbox eliminator? If not, take the bike elsewhere, as the dealer or mechanic is assuredly a moron. See the jetting guide available on Peter Jenks' website for the necessary info. Oh, and if those caps come off, you're sucking unfiltered air into your engine, which will eventually do bad things to your cylinder walls.
3) On three different occasions while sitting at a stop light with the bike in neutral the engine has been purring along and then - there is a slight grinding or light crunching sound - the bike's motor hesitates for a brief second and goes right back to purring. It make me think awful thoughts about what is happening inside my engine. ????
Ummm... that ain't right. Not sure what it is, but it ain't right. Could be something as simple as an idle circuit that has a bit of dirt in it. Or more serious stuff. If your dealer can't fix it, find a different dealer.
4) At higher speeds going into turns the bike's front end gets unstable (shakey and twitchy). Is this a dampener hint?
How's your tire pressure? Rear wheel alignment? These bikes are pretty rock solid handlers. Should track nice and true through bumpy turns, to say nothing of smooth ones. Heck I coasted down from 70 mph to 35 mph today with my hands off the bars, and thrashed hard though twisty back roads on my morning commute. My Bonnie handled flawlessly, regardless of the demands placed on her. Yours should do likewise.
Sorry to hear of your troubles. Hope things work out, and that these suggestions are useful.
[ This message was edited by: bmetz99 on 2007-05-11 01:14 ]
