RacerPartsWholesaleBikeBanditShopTriumph.comCycleGear.comTrident-Exhausts.combritishcustomsSportbikeTrackGearAnnitori DistributingSpringfield ArmoryMotorcycle.com
Old 05-10-2007   #11 (permalink)
Any further developments on the subject of Thruxton pipes on a T100? I have an '02 T100 and have a vested interest in this conversation.
DaveInPortland
Work to Ride. Ride to Work.
DaveInPortland is offline   Reply With Quote
Old 05-10-2007   #12 (permalink)
For me it was a direct bolt on, headers came off a 04 Thruxton.. The cans are D&D for a Thruxton.. John, had to put a flat washer under his right peg mount to space it out a small amount.. If you look on the right side where the spring connects for the break pedal, that is what John had a issue with.. Hope this helps!! If anyone needs some close up pic, send me a PM...
Keith...
1409 is offline   Reply With Quote
Old 05-10-2007   #13 (permalink)
Favorite Bike: 1087 Triumph
Bonnie1000th's Avatar
Other Motorcycle: 1250 GSF
Interesting...
Tooo many mods!
1087
T100 Lucifer Orange bonneville.
http://www.triumphrat.net/photogallery/v/member/album788/album1500/aas.jpg.html
Bonnie1000th is offline   Reply With Quote
Old 05-11-2007   #14 (permalink)
Yes the thruxton pipes bolt right on a T100 or bonnie. Mine had a slight clearance issue with the little bracket for the pedal return spring - I could have filed a 1/16" off - but opted for a washer behind the foot peg mount.
Here is were it's tight.
Thruxton system with Thrux TORS.
http://www.triumphrat.net/memberalbums/data/500/thumbs/dragon1.jpg
John W.
  • 04 Thruxton – Graphite & Opal
  • 06 T100 – Black & Red
  • 05 T100 - Black & Opal - Project Bike
  • 51 T100 – Silver & Black
Thrux-ton-up is offline   Reply With Quote
Old 05-11-2007   #15 (permalink)
Commando: Just the mufflers. I figured at most, I'd have to bend it slightly with a torch.
Thrux-Ton-Up: Thanks so much for the info. That close up is incredibly helpful.
Thanks to everyone for the info. Will post pics when I get them on.
Cheers!
TheSharking is offline   Reply With Quote
Old 05-24-2008   #16 (permalink)
Smile
hi did you have to bend
cheers
jim
jimpilk is offline   Reply With Quote
Old 05-24-2008   #17 (permalink)
The Thrux cans will fit your bonnie headers without any mods. Its direct bolt-on.
Soulrebel is offline   Reply With Quote
Old 05-27-2008   #18 (permalink)
Smile
cheers mate
jim
Old 06-06-2008   #19 (permalink)
Wink
hi all fitted thursday seam ok no leaks as anyone drilled the
centre to make them a bit louder
cheers jim
2005 Thruxton Superhawk29 Twins Technical Talk 2 08-19-2007 02:23 PM
louder pipes for 2005 bonnie roccotacco21 Twins Technical Talk 15 12-19-2006 12:07 AM
2005 Thruxton for $6K DanPtWash Speed Triple Forum 3 09-12-2006 12:54 PM
2005 Speed Triple Dyno #'s- stock, pipes, pipes&map RbtWbbr3044 Speed Triple Forum 90 03-22-2006 10:23 PM
Idle Problems on 2005 T-100 sacco Twins Talk 5 10-10-2005 05:02 PM
