Three options: If you opt for the adapter that goes inside of the bars, you can drill out the existing end plug with a 5/8" or bigger bit. The CRG adapter will fit right into that and the mirrors will hold. The other inside option is to tap the thread in the bar plug big enough to fit the screw of the adapter inside of and do away with the locking puzzle piece of the adapter. The final option is to push the grips in 3/8" and mount the mirrors on the ends of the bars. However, if I recall correctly, the Bonne bars are too big to mount mirrors this way. Good luck, you will like these way better than stock.
Death or Glory
Rides a 2007 T-100
