Motorcycle.comBikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 05-09-2007   #1 (permalink)
Favorite Bike: Triumph Thruxton
itcha's Avatar
Just rejetted recently and seems I may be off and need some advise.
I have added a 125 main jet and 1 shim. My modest mods are uni air filter, snorkle out, AI removed and Emgo reverse cones.
Finding that the bike feels a bit sluggish in the mid range when first started, once the bikes warms up it seems a lot more responsive in the mid range and runs pretty good. Checked the plugs and they look like I am running rich.
Was just wondering if I should remove the shims and go smaller on the main jet or should I just remove the restrictor plate from the airbox and stay with the setup I have now???
Cheers,
[ This message was edited by: itcha on 2007-05-08 23:44 ]
itcha is offline   Reply With Quote
Old 05-09-2007   #2 (permalink)
if you remove the baffle, it'll probably run. I'm at 130's with your basic setup but no shim, runs very well
G
I just wanted to ride
Old 05-09-2007   #3 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
My recommendation would be to start by taking off the shims from the needles, and see how it runs in the mid-range. Don't be surprised if you find you need a little different set-up than other Thrux's with similar mods. A dyno run with EGA is about the only real way to tell where you are mixture-wise in the mid-range. Your main jets should be pretty close for your current set-up. I think 130 would be about the maximum size you could run with that setup.
Larry
Larry
Old 05-09-2007   #4 (permalink)
I forgot to mention: Think of the mid-range as 4000--6000 rpm. Below that and your pilot mixture has some affect. If the area of sluggish feeling is below 4000 rpm, do some adjustments with the pilot screws--try both leaner and richer settings. Above 6000 rpm, the main jets come into the picture.
Larry
Larry
Old 05-09-2007   #5 (permalink)
Favorite Bike: 2006 thruxton
I had the exact same setup as you and found mid-range to be a little weak. I added an additional shim and it runs much better.
I still intend to get a dyno run eventually
bronsonj is offline   Reply With Quote
Jetting Whitehurst Club Cafe 4 12-24-2007 05:07 AM
Jetting? Lion Twins Technical Talk 8 03-16-2007 09:18 AM
D&D Jetting technogrunt Twins Technical Talk 6 03-01-2007 08:57 AM
The Jetting is done... GrahamC Twins Technical Talk 4 08-31-2006 01:53 PM
Jetting - I don't get it. d2mini Twins Talk 12 09-19-2005 09:02 AM
