Trident-Exhausts.comSportbikeTrackGearMotorcycle.comSpringfield ArmorybritishcustomsCycleGear.comShopTriumph.comTriumphPerformanceUSABikeBanditAnnitori Distributing
CycleGear.com
Old 05-07-2007   #1 (permalink)
Favorite Bike: 2002 Bonneville 790
Other Motorcycle: 06 HD Heritage Softail
Extra Motorcycle: 1981 BMW R100RT NEEDS TL
I have seen the adj. brake lever @ NBV but not a clutch lever. Where can I get one?
jerseyjeff is offline   Reply With Quote
Old 05-09-2007   #2 (permalink)
Jeff - had to replace mine in the fall, and got it from Triumph.
jquattro is offline   Reply With Quote
Old 05-09-2007   #3 (permalink)
This is where I got mine. This is listed for the Thruxton but I am fairly certain you would be able to put one on the Bonnie.
Adj Clutch Lever at Bike Bandit
6449 is offline   Reply With Quote
Old 05-09-2007   #4 (permalink)
Favorite Bike: Black Bonnie
T100's have adjustable clutch and brake levers My Bonnie only came with the clutch. Can I buy the brake lever and put it on? Or are there other parts needed? Sorry for hijacking the thread, but it's the same type of question.
-Aaron
Colonel_Dorkus is offline   Reply With Quote
Old 05-09-2007   #5 (permalink)
You can get them @ BikeBandit like kingmoham said. You will also need to order the housing and the pin to make it fit (also available @ BikeBandit).
If you are looking to get the lever a little closer to the grip, the adj lever may not be for you. That is what I was looking for and I am actually more comfortable with the stock lever.
2005 Bonnie Black
jcline8 is offline   Reply With Quote
Old 05-10-2007   #6 (permalink)
I've fitted the adjustable brake lever, & the shop told me the clutch lever for the T100 should fit straight on, £35.00 ish
using a intel imac & a Tiger 1050
Dickie2679 is offline   Reply With Quote
Adjustable clutch lever Boilerskull Hinckley Classic Triples 3 06-23-2005 06:10 AM
adjustable clutch lever djr Tiger Mods & Bolt-Ons 2 06-14-2005 03:12 AM
span adjustable clutch lever. georamage Speed Triple Forum 2 01-09-2005 02:03 PM
Adjustable clutch lever..need help boxsky Modifications & Workshop Talk 4 10-26-2004 05:26 PM
Adjustable clutch lever? 03tiger Tiger Chat 3 09-15-2004 10:25 AM
