» Links |
05-07-2007
I did a search and couldn't find the answer to this one, so, sorry, but...
How do I get the rear side reflectors off my bonnie? They aren't secured by any bolts that I can see, like the front ones.
Thanks,
Andrew
SuperSport Favorite Bike: 2003 Triumph T100
Posts: 1,086 Other Motorcycle: 2007 M-G Cali Vintage
These reflectors are secured with double-sided tape. Just take one end and start easing it up. With a bit of effort, they will lift off. If there is any tape residue, wipe it off with some Goof-Off or some other sort of mild solvent. You'll never know it was ever there...
05-07-2007
I used a bit of dental floss to saw through the tape and hardly any of the sticky stuff was left behind. I think it helped that I did it outside in the summer after they were good and warmed up. I was surprised how easy they came off.
Kansas City, MO
'05 Bonnie Black
05-07-2007
*****, I need some more advice.
I did it, and I think it definitely looks better without the reflectors, but there is a small chip in the paint, now.  I'm not sure how it happened. I heated the area with a blow dryer for about 3 minutes, then gently used the floss sawing method. Thought all was fine, but alas, there is a small chip now.
Any ideas? Can I take this to a shop somewhere and have them fix it? Or is there something I can do myself?
05-07-2007
Location: Toowoomba Queensland Australia (gods country)
You could always cover up the chip by gluing a reflector over it!!!! :-D
or just use a dab of touch up paint on the chip.
Ozbon's album
old enough to know better...young enough not to care.
05-07-2007
If your dealer doesn't do touch-up paint (like my local dealer), it's available from Bike Bandit.
Marty
05-07-2007
Warm em up with a hair dyer to weaken the glue.
Thats what I used to do to remove masking tape from pinstipe patterns on paint jobs.
05-07-2007
+1
I did this and they almost feel off. WD-40 will easily remove the glue residue.
2005 Triumph Bonneville Black
05-07-2007
Just pick out your favorite color and repaint her! :-D
05-07-2007
cut the fender off?
