As anybody with the Triumph grabrail and sisybar will tell
you there aren't many options for saddle bag support rails -
especially if you have already relocated your rear turn
signals. I wanted supports that could be removed quickly,
looked good and didn't cost a fortune. This idea came from
our ole buddy Copper's use of the Drag Specialties saddle
bag support rail. Copper found out the rails needed some
help in order to get them to stay put, but being an
obsessive sort, I would never feel comfortable about that
open-sided bolt hole. I was planning on cutting it up and
having a friend weld a new piece of angle iron on but it
turned out to be unnecessary.
So here's a quick and easy upgrade to Copper's solution.
Copper's pic of the Drag Specialties saddle bag rail part number DS110854.
(I bought mine at Dennis Kirk for $52.95 a pair).
Make a guide mark to help you find your side-to-side
position the bracket. You don't want the hole too close to
the edges.
Remove the front bolt and washer from the Triumph
sissybar/grabrail and also loosen the rear bolt slightly. Then
slide the support all the way up (between the dresser bar
and the grabrail/sissybar) until the horizontal part of the
bracket hits the bottom of the dresser rail. Make sure your
initial mark is centered in the hole and then mark the center
of the hole itself on the bracket.
Remove the bracket and use a center punch to make an
indentation on your mark.
You will need to drill a 5/16" hole. Start buy using a very
small bit to make enough of hole to keep the bigger bits
from traveling. I used a 3/32 then a 1/8, then a 1/4 and
finally a 5/16. No need to drill all the way through for the
first two bits. Use a alternating pressure while drilling.
Then just slide 'er in, replace the front bolt (sans front washer)
and tighten both front and rear bolts. Done!
You can add or remove them in under a minute!
A nice tight fit against the dresser rail ensures that the
support will not swing back and forth.
Here she is ready for an expedition this summer!
Thanks to Redbird and Curefan for the info on the Cortech
bags. I love em! I ended up finding the lowest price from a
mailorder house just a few miles from me. They let me come
in and throw different bags on bike to see how I liked them.
Excellent service!
www.motogearoutlet.com
[ This message was edited by: Ridge on 2007-05-06 22:00 ]
