Motorcycle.com
Old 05-06-2007   #1 (permalink)
slade
hi folks, just joined, coz i've had my '01 bonny 9 months now, it had 639 miles on the clock when i got it n now its got 1300, had been dry stored from new and i was the first person to get it serviced, took it out for a blast yesterday, when i got back my m8 pointed out an oil spatter on the rh side pannel, so while he continued with all the usual 'british oil slick' jibes i got to investigating the source.
turns out to be coming from the head gasket at the rh front headbolt flue.
has anyone had this happen b4?
what suggestions are there to fix it?
is there anything else i need to look out for?
Old 05-06-2007   #2 (permalink)
Favorite Bike: 2006 Triumph T100
Other Motorcycle: 1968 Triumph Bonneville
Extra Motorcycle: 1972 Suzuki T500
Are you sure its oil? could be the corrosion preservative they are sprayed with when shipped from the factory
John
New Plymouth
New Zealand
Nzbiker is offline   Reply With Quote
Old 05-06-2007   #3 (permalink)
Yeah could be?? If not & gasket- put a torque on the head bolts. Its older so anything could happen>? I dont think major either way? :hammer:
CAPT D
Old 05-06-2007   #4 (permalink)
Favorite Bike: '06 Bonneville Black
Other Motorcycle: '89 FXR
Considering it has been sitting for some 5 or 6 years...it is most likely the cam cover gasket that is leaking. Removal of the cam cover and a little sealer will go along way.
Have any pics?
Hated By All....cause thats just how it is.
SCCTrim is offline   Reply With Quote
Old 05-07-2007   #5 (permalink)
i have the same problem on my 07 Bonnie. Taking it on Thursday to get resealed. No biggie.
NYCyclist is offline   Reply With Quote
Old 05-08-2007   #6 (permalink)
slade
hi folks, noop, def the head gasket not the rocker cover, will torq down and see wot happens.....
noticed sommit else too,seems to drag on 1st gear at low speeds,clutch in, coasting, almost as if its not quite in gear properly or one of the cogs is catching, but it is firmly in gear.
any thoughts?
Old 05-08-2007   #7 (permalink)
Retired Legend
sweatmachine's Avatar
Daz, I've taken mine off probably a 1/2 dozen times and I've always reused the original gasket, with a little bead of RTV. Why use a new gasket every time? This cover doesn't need it.
alright alright alright
Bonnie cafefighter!
Old 05-08-2007   #8 (permalink)
any thoughts?
Sounds like the clutch chatter problem most early bikes had, if you are lucky Triumph might still give you a new basket to fix it. What oil do you use? It gets worse if you don't use synth mc oil. Adjusting the cable might also help, but the fix is still a new basket.
jojje1963 is offline   Reply With Quote
HELP! oil leak from osf corner of head gasket,only 1300 miles on the clock slade Twins Technical Talk 1 05-08-2007 05:47 PM
05 speed 3 head gasket leak jnicosia Speed Triple Forum 6 11-25-2005 07:00 PM
Oil Leak head gasket? and looking at Dennis's T100 at dealer jwpT100 Twins Talk 3 11-17-2005 08:39 PM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 08:43 AM
Head gasket oil leak - comments........ shards Speed Triple Forum 5 09-12-2004 02:06 AM
