Old 05-04-2007   #1 (permalink)
Favorite Bike: MINE OF COURSE!
unitedrocker's Avatar
Other Motorcycle: 2005 KTM 450
Extra Motorcycle: Coletta 6'2" pintail
I've done a few searches, but nothing solid came up.
Looking for jeting FAQ, mainly for:
Thruxton
Bonneville
T100
with:
Basic (free) airbox mods, high flow mufflers
Aribox removal, high flow mufflers
Numbers to change on:
Main, pilot, needle, fuel mix
I would assume that the baseline would be close for anything sea level to a 1000 feet.
THANKS! Okay, gotta get to work... check back later. :hammer:
Never settle for the usual.
'05 865 Thrux-ton - Super-Duper Modified: painted inner tube caps yellow, purple tassels on the bars, and pink neon lighting.
unitedrocker is offline   Reply With Quote
Old 05-04-2007   #2 (permalink)
bonnieblackinfl's Avatar
Depending on how free flow your cans are I would start with:
42 pilot
150 main
No shim on the needle
Then head to the dyno and get a good a/f ratio reading at 1/4. 1/2, 3/4, and full throttle. Make some witness marks on your throttle in 1/4 turn increments to verify the run and note each a/f reading at each mark. The carbs work on throttle position, not rpms. I hope this helps.
Greg
bonnieblackinfl is offline   Reply With Quote
Old 05-04-2007   #3 (permalink)
Best single source is the Jenks Tuning Guide, available as a downloadable pdf here:
Jenks Guide
2005 T100
Old 05-04-2007   #4 (permalink)
Cool beans... I'll make a note of this jetting... should be a sticky in this forum. :hammer:
[ This message was edited by: unitedrocker on 2007-05-04 18:26 ]
Old 05-04-2007   #5 (permalink)
Favorite Bike: My one-and-only '03 Bonne
pabonne's Avatar
Check out the wiki page (if you haven't already). Lots of good carb info there (and other popular mods too).
2003 790 (black, not Black) KARK'd, K&N Cones, Staintunes, 130/42 jets, 2.5 turns out, BC Superbars, CRG LS mirrors, Generic Rubber, 16t
Why? Too many H-D's.
pabonne is offline   Reply With Quote
Old 05-05-2007   #6 (permalink)
Aside from the Jenks Guide, the following have been helpful to me:
Basics of the Keihin Carb
Carb Jetting Instructions
Float Height
2005 T100
Old 05-15-2007   #7 (permalink)
NICE!
The Old Hinckley Triumph FAQ KitNYC T3 Sport / Touring Forum 0 02-15-2008 07:01 PM
FAQ - Read this first before asking questions! dfib Speed Triple Forum 5 10-07-2007 07:19 PM
Sprint ST FAQ ike9 Sprint Forum 1 03-01-2007 09:14 PM
Didn't see this one in the FAQ... Hinckley Classic Triples 1 09-13-2004 02:03 AM
