Hotter than fire! - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleMotorcycle.com
Old 05-01-2007, 11:11 AM   #1 (permalink)
5bassman's Avatar
After a short ride on my Bonnie (20 miles?), my rear disk is scorching hot. Obviously the pads are sticking but why? It's been that way since I bought the bike used.
2005 Triumph Bonneville Black
5bassman is offline   Reply With Quote
Old 05-01-2007, 11:20 AM   #2 (permalink)
Favourite Bike: 1972 Suzuki TM 250
Loxpump's Avatar
I've had pads stick on a car before and it was the piston in the caliper that was frozen up.
Stop Global Whining!
Semper Fi!
Loxpump is offline   Reply With Quote
Old 05-01-2007, 11:22 AM   #3 (permalink)
Legend
Favourite Bike: 904cc Bonnie w/magwheels
sweatmachine's Avatar
probably the original brake fluid. It can corrode, and you're *supposed* to flush it out and replace it every so often. Your pistons probably have corroded in the rear caliper.
Old 05-01-2007, 11:41 AM   #4 (permalink)
5bassman's Avatar
The rear brakes work fine but aren't releasing fully.
Old 05-01-2007, 11:48 AM   #5 (permalink)
Favourite Bike: 2007 Bonnie Black
xardoz's Avatar
If you're still in the waranty, I'd take it in to the dealer.
xardoz is offline   Reply With Quote
Old 05-01-2007, 12:23 PM   #6 (permalink)
Favourite Bike: Street Triple R
Rincewind's Avatar
Other Motorcycle: Savage
Did you refrain from using your rear brake during the entire ride? If you are using it at all, you can expect it will get very hot.
Rincewind is offline   Reply With Quote
Old 05-01-2007, 02:25 PM   #7 (permalink)
cw
Favourite Bike: 2006 Scrambler
If the brake pads are worn down the pistons can become canted if they protrude too far out. This prevents them from fully retracting.
Changing the brake pads can fix this.
However as was mentioned, if the brake fluid is dirty you should go ahead and replace it (simple job).
cw is offline   Reply With Quote
Old 05-01-2007, 03:06 PM   #8 (permalink)
I'm sorry, but I cant go along with this dirty brake fluid theory. The bike is only 2 years old for heavens sake. :???:
ChrisV is offline   Reply With Quote
Old 05-01-2007, 03:21 PM   #9 (permalink)
Favourite Bike: My Bonnie
Other Motorcycle: My other Bonnie
Extra Motorcycle: '98 FXD
Make sure you're not riding the rear brake...I had to lower the pedal on mine to clear my big feet
...Billy
Shoot safe, straight and often...
BILLYSIM is offline   Reply With Quote
Old 05-01-2007, 03:38 PM   #10 (permalink)
Favourite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
Mine's the same way. It's a 2005 bike that I bought brand new in Feb. The rear brake works fine, but it gets very hot. I took it to the dealer, and they told me it was fine. I was, and continue to be, skeptical; but I've put almost 2,000 miles on the bike since I got it and the pads look almost brand-new, so I figure that (a) it's not affecting my braking; and (b) it's not affecting the longevity of the pads; so (c) I'm not worrying about it right now. At some point I'll take a more serious look at it; but I think the rear brake gets poor air circulation, and obviously all brakes generate a lot of heat in use, so I'm not worrying about it.
2005 Aegean Blue Bonneville - Intiminators and Thruxton preload adjusters up front, Ikon 7613s in the back, otherwise stock
2012 Azzurro Fiat 500 Sport
lindsayt is offline   Reply With Quote
Running hotter lately SpeedTrippy Speed Triple Forum 1 09-23-2007 05:24 PM
Running hotter on the Right! webonnielad Twins Technical Talk 10 08-22-2007 08:00 AM
Hotter Plug? Hairball Speed Triple Forum 8 07-24-2006 12:31 PM
one side way hotter than the other trav13 Twins Talk 15 05-02-2006 02:48 PM
Hotter thermostats? fartinmartin Sprint Forum 10 01-30-2006 04:53 PM
