Installed wider 34.5" bars. Now cabling & revving issues. - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com
Old 04-30-2007, 10:05 PM   #1 (permalink)
Favourite Bike: my 1969 TR6C
Just installed some lower rise bars on Scrambler & fit everything back on, but it's pulled very very taut, esp on throttle cables & front brake cable. On testing it, when I turned bars to right, thus pulling cables very tight, it revved the motor, as if the tension on the cable was somehow allowing more gas. Then as soon as I straightened bar again, it went back to normal. Dunno, if I should chop bars or go with longer cables, which seems pricey.
clamp007 is offline   Reply With Quote
Old 05-01-2007, 03:51 AM   #2 (permalink)
Get the western cable kit from new bonnie. It is nice norman hyde stuff. I love my western bars.
Mods= hepco's with topcase, parabellum, k/q seat, great bay highway bars, norman hyde pipes, bellmouth,progressive rear hagon front susp, ird plugs. Looking into russell day-long seat.
evand is offline   Reply With Quote
Old 05-01-2007, 04:20 AM   #3 (permalink)
Favourite Bike: Speedmaster efi
eagle's Avatar
Other Motorcycle: '75 Bonneville T140V
Yeah! Someone else with western bars! I thought everyone was going down the cafe racer or tourer route!
Always forgive your enemies,
Nothing annoys them more
eagle is offline   Reply With Quote
Old 05-01-2007, 07:30 AM   #4 (permalink)
5bassman's Avatar
My Arlen Ness Flattrackers did the same. You may get some slack in the cables where they are attached to the frame.
2005 Triumph Bonneville Black
5bassman is offline   Reply With Quote
Old 05-01-2007, 08:55 AM   #5 (permalink)
I got the Western bar kit from New Bonnie. Love it. I had to play with the cables to get them sorted out but it was no big deal.
[ This message was edited by: mn9130s on 2007-05-01 06:56 ]
mn9130s is offline   Reply With Quote
Old 05-01-2007, 10:51 AM   #6 (permalink)
Can one do the replacement oneself, or do you need a mechanic? That would get costly.
I wouldn't know how to replace those throttle & idle cables. I'm wondering if there's any slack in the throttle cables where they go under the tank. All I need is an inch & a half.
Don't the Triumph America, Speedmaster or Rocket 3 have longer cables which I could use. That seems cheaper if they'd work.
Old 05-01-2007, 12:11 PM   #7 (permalink)
Just fitted longer cables & brake hose to my bike yesterday, the only hard part was getting the throttle cable 'nipple' attached to the carb.
Brake lever feels better (firmer) but I've not had time to test the bike up the road.
using a macbook pro,Street Triple and a 1958 Land Rover. (wife has a british built Honda)
Dickie2679 is offline   Reply With Quote
Old 05-01-2007, 08:30 PM   #8 (permalink)
The hardest part of the replacement was getting the throttle cable attached to the carbs. Definitely a DIY, no special knowledge/tools needed. My original cable didn't have enough slack to make it, if the America etc has longer cables that might just be the ticket for you. I personally don't know.
Old 05-01-2007, 09:29 PM   #9 (permalink)
grayghost's Avatar
I installed Western bars from Bella Corse on my 07 T100 and it was fiddly getting the cables oriented just right. It was pretty tight. It did work out and am pleased with the bars.
I also just installed S/S brake lines as well (stock length) from Bella Corse and they fit without issue.
" My bike pulls to the left......or the right....depending on what side of the road the Tim Hortons is on"
grayghost is offline   Reply With Quote
Tomaselli Bars installed thruxtonone Club Cafe' 16 07-29-2009 08:30 AM
Handle bars, higher and wider Motolink Twins Technical Talk 44 01-04-2008 11:20 AM
M-bars installed meister Twins Technical Talk 8 04-28-2007 08:38 PM
New flat track bars installed RT Twins Technical Talk 6 10-24-2006 04:10 PM
Installed Rizoma bars and risers OKCTriple Speed Triple Forum 6 09-18-2006 09:39 PM
