04-30-2007, 03:45 PM
Team Owner Favourite Bike: 2003 T100
Posts: 5,474 Other Motorcycle: 1991 BMW R100GS Extra Motorcycle: 2008 Guzzi 1200 Sport
Can someone supply me with the Part No for the Pingel petcock which some of you use to replace the stock Triumph one? I'd like to see if they can provide a vacuum-operated one that is identical in size, mounting holes, etc. That way, I'd set the T100 up like the W650, and wouldn't always be finding the gas left on overnight.
Bob
04-30-2007, 04:59 PM
Team Owner Favourite Bike: 04 Bonnie black
Bob,don`t know about a Pingle,but one of our European cousins [Pepe maybe]had installed a petcock from a Suzuki 650 [not sure which model] that was small,chrome and vacuum operated.Looked sweet. :???:
04-30-2007, 05:10 PM
Oops,sorry Bob. I looked it up and the valve is not vacuum operated. Still looks good though.
gas valve
04-30-2007, 05:57 PM
Thanks, Rodburner .... I know Pingel has some vacuum operated petcocks, since they asked me to send measurements (hole to hole, which side of tank it was on, which direction the fuel line attaches).
I thought since Pingel already supplied a non vacuum version, I'd ask if they had a similar one with a vacuum hook up.
Bob
04-30-2007, 10:30 PM
I would go to the Pingel website and get contact info. Then call them and give them the info they need to recommend a petcock. You will need to make sure that everything on the back of the Pingel (vacuum line spigot, fuel line spigot) will clear the throttle cables.
2005 T100
05-01-2007, 07:56 AM
SuperSport Favourite Bike: 02 Bonneville
Posts: 1,032 Other Motorcycle: 1972 Honda CL450 Scrambler
Bob...I checked last night to see if I still had the packaging on mine, but couldn't locate it. I believe the model used is the 6211-CL or 6311-CL Series. They do have a Vacuum model 6311-CRV which appears to be similar.
Shorty
05-01-2007, 10:38 PM
Shorty - thanks for the info. I'll use your part numbers as a reference point when I contact Pingel. I'll bet your numbers are right on the money!
Bob
