Hi Guys
Can anyone tell me if the Hagon Progressive fork springs, shorten the length of fork travel?
In comparison to the stock triumph springs.
If so by how much?
I already have them waiting to go, on my front end, which I am lowering by 22mm. I'm hoping to get this done Friday evening GMT.
Jon (UK)
