I guess you really need to talk to someone who customizes and adapts original frame parts on bikes.
You might start with a Haynes manual for the oil in frame type Triumph and take it from there.
There's a guy who knows a lot about old Triumphs called Sandy Bandit up near Portland Oregon.
I went there once on a visit to my friend in the U.S.
He must have had 90% of everything Meriden ever exported to the U.S. in his place.
Other than that I can't say.
Try the owners club.
I guess your like me you know how to spell , but when it comes to playing the keyboard, you don't necessarily play the keys in the right order.
Good Luck.
Jon (UK)
