Old 04-28-2007   #1 (permalink)
Favorite Bike: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
OK people
thinking of pulling the snorkel off butt when looking at it i was wondering about riding in the rain looks like all the water would end up in the air box anybody have a problem with this don't plan on rain but s*** happens
thanks for your help
jerry
toys for big boys
wildchild is offline   Reply With Quote
Old 04-28-2007   #2 (permalink)
Favorite Bike: 05 TBA
ErwinM's Avatar
Other Motorcycle: 1997 GT mountian bike :)
you can always pull the snorkel out, cut off the part that goes into the filter and then reinstall the top. Just like not having a snorkel with the same water protection.
Erwin
Erwin
ErwinM is offline   Reply With Quote
Old 04-28-2007   #3 (permalink)
wildchild's Avatar
thanks for the reply i was thinking about that cutting it off just under the plate but didn't know if that would do the same as removing the whole thing are not
jerry :-D
toys for big boys
Old 04-28-2007   #4 (permalink)
ErwinM's Avatar
All clear as "Mud" now :-D
Erwin
Old 04-28-2007   #5 (permalink)
wildchild's Avatar
Erwin
enlighten me more have 07 speedy had tors put on it before picking it up they said they went up 2 sizes in the jets so know if i de-snorkel it i don't think i have to do anything to the jets tell me is that thinking right or wrong thanks for your help
Jerry :-D
toys for big boys
Old 04-29-2007   #6 (permalink)
OK Wildchild.Out west here it doen't rain a lot I know. I removed the snorkel completely on my Speedmaster and I also cut a hole in the bottom of air box as some say to do.Yes it does breath ALOT better,but you need to rejet with this mod. The other drawback is it {does get water into the air box}!!!! I put a small piece of heater duct hose into the bottom of the air box and so far this seems to help,but as I said we do not get alot of rain. I also have the stock K&N replacement filter.I could not see going with the duel K&N's that do away with the air box completely because of all the dust here in the desert. Opening the air box up does help it breath.I know it's a toss up on what to do. I like the performance though!!! :-D :-D
speedblue is offline   Reply With Quote
Old 04-29-2007   #7 (permalink)
ErwinM's Avatar
Hey Jerry,
Most of the info for jetting I got from Dinquas Jetting calculator and BA.Com. I would think you might need to up the jets a bit but not knowing whats in there now, its hard to say.I would recomend removing the AI system if you havent done that already. It will save you pipes from discoloring.
Erwin :hammer:
Erwin
Old 04-30-2007   #8 (permalink)
Favorite Bike: Speedmaster
Binnsy's Avatar
Wildchild, I pulled the snorkel and have NEVER considered putting it back on.
I first trimmed a bit off, then a bit more, and more, and finally it has gone completely and I have enlarged the hole to the size of the hole in the K&N filter.
Trust me, mine runs and sounds heaps better without it. Have had a bit of water sucked in but one day I will silicone a bead around it to fix that little problem.
I had to dyno tune and rejet to get it perrrrfect. :-D
Scientists say too much alcohol damages your memory, I forget why...
Binnsy is offline   Reply With Quote
Snorkel? Kramocker Twins Technical Talk 7 09-17-2007 02:18 PM
Snorkel ? 2Marks Twins Technical Talk 1 11-25-2006 12:01 PM
What is the snorkel? Torro Twins Talk 19 06-12-2006 07:36 PM
What is a snorkel?? lbo Twins Talk 19 09-17-2005 10:15 PM
snorkel in or out? mrgadget Twins Talk 7 06-20-2005 02:34 PM
