This is my first post here. I recently bought my first bike, an '06 Speedmaster, and I love it. On my way to work today, my right turn signal went out (both the signal and the indicator light on the tank). It also makes a buzzing noise. Is there a quick fix for this, or do I need to bring it back to the dealer?
So eventually both right and left signals, the brake light, and the horn went out. I blew three fuses trying to fix it, and finally sent it back to the dealer. It turns out there was a bad connection in the right rear turn signal.
[ This message was edited by: raff on 2007-05-23 15:56 ]
I had a similar problem and the pins/plug on the front left position of the handlebars were "menza menza". Hit it with a little spray lube, worked the plug on /off//on and all is good now . Erwin
