Depends on what year you're talking about. If you are looking at last years models, the 06's, then theres a lot more to consider. But in 07 they changed them and they are much more similar. For example, the america had spoked wheels till 07 when they gave it cast wheels, while the speedy has always had cast wheels. The america did not have a black engine like the speedy has always had till 07. The america's engine was a 790 till 07 at which time they changed it to the same 865cc engine as the speedy. So you can see they are much more similar now.
The main considerations beside which YOU think looks better in th 07's are these....
america has no tach, speedy does
speedy has dual front discs
speedy's seat isn't as good for passengers as america (tho i think it looks way better)
If you opt for an 06 then they are much more different with different engine sizes that also have different cams, mags vs spokes, engine color, etc. I personally think the america looks better in 07 than it did previously, but i think the speedy looks worse now. The paint scheme was much better till 07 IMO too.
