BikeBanditAdvanstarMotorcycleShowsMotorcycle.com
BikeBandit
Old 04-23-2007   #1 (permalink)
Favorite Bike: '07 Black & Red T100
slowgator's Avatar
Other Motorcycle: '70 T120R Bonneville, '78
Recently bought a new 2007 Bonnie T100. Owner's manual recommends lubing the chain every 200 miles. My Bonnie has no centerstand. Any tips on lubricating the chain without a centerstand?
Pat
"Some people never go crazy. What truly horrible lives they must lead." - Charles Bukowski
slowgator is offline   Reply With Quote
Old 04-23-2007   #2 (permalink)
Favorite Bike: Velocette Thruxton
Thruxton's Avatar
Other Motorcycle: BMW R1100RS
Extra Motorcycle: 67 BMW R60, with sidecar
You can lube some of the chain, then roll the bike and lube the rest.
BUT, I recommend you get a centre stand, it will be money well spent; I never owned a motorcycle that didn't have a centre stand.
Crazy Old Bastard.
62 years old and I still don't know what I want to be when I grow up.
Loud pipes are rude and inconsiderate.
Thruxton is offline   Reply With Quote
Old 04-23-2007   #3 (permalink)
Favorite Bike: 2008 Victory Kingpin
Silverado57's Avatar
Other Motorcycle: 2006 Victory Vegas
Extra Motorcycle: 2005 Speedmaster (Ret.)
Build a $20 bike lift out of 2X8s and an iron pipe.
Easy!
CLICK HERE
Kevin
Luceo Non Uro
NJ USA
Silverado57 is offline   Reply With Quote
Old 04-23-2007   #4 (permalink)
Before I installed a center stand, I would invite a buddy over for a beer and make him slowly walk the bike while I sprayed the chain.
Captain is offline   Reply With Quote
Old 04-23-2007   #5 (permalink)
Spray.
Roll Back.
Repeat.
Mattrat is offline   Reply With Quote
Old 04-23-2007   #6 (permalink)
Favorite Bike: 2003 T100
ohiorider's Avatar
Find a way to get the back wheel off the ground. That can be a center stand (which I recommend if you use your Bonnie to tour), a bike lift, a simple home made lift as others have suggested.
The Bonnie is the first bike I've owned (out of a total of 13) that didn't come stock with a center stand. So, in my case, the first accessory I installed was the stand.
Bob
Old 04-23-2007   #7 (permalink)
MAR
Favorite Bike: Thruxton
Other Motorcycle: Ducati 916
Extra Motorcycle: Aprilia Falco
If you have a floor jack, place a rag or block of wood on the lift and place it under the right side of the frame while the bike is on the side stand. Slowly lift the right side and pivot the bike on the side stand and the front tire. Only go far enough so the back tire is off the ground.
If no stand is available I have done this alone by pushing the bike on the the side stand with one hand and spraying the chain with the other. If a friend or spouse is around they can hold the bike leaned over for you on the side stand as you spray the chain.
"What are you rebelling against?"
"What have you got?"
MAR is offline   Reply With Quote
Old 05-11-2007   #8 (permalink)
slowgator's Avatar
After "rolling" the bike to lube the chain and having it fall over, I will be paying about $930 for repairs and a new centerstand. While I realize it was my own carelessness that the bike fell over, be warned that Bonnies do not fare well falling over off the sidestand! The shift peg broke off, the left turn signal broke, and the left headlight bracket bent. OUCH! On a Bonnie with only 1,000 miles on her, that HURT!!! I only wish I had invested the $240 for the centerstand when I got her. Expensive lesson.
In light of these events, I strongly recommend a centerstand.
Old 05-11-2007   #9 (permalink)
Favorite Bike: bonnie T100 '06
greyplague's Avatar
Other Motorcycle: BSA B 31 1954-for sale
I made something out of some sheet metal, two pieces of tubing and some leftover roller bearings after "stealing" this idea out of a catalog : roll the rear wheel upon the tool, put a block (pic) under the side stand and spin the wheel!
Whatever doesn't kill me makes me older.
greyplague is online now   Reply With Quote
Old 05-11-2007   #10 (permalink)
I'm really sorry that you dropped the bike. That's miserable.
You don't have to lube the chain every 200 miles. 500 is more reasonable, and that's more or less what I do.
PS I got the center stand not long after I bought the bike.
Marty
WHAT CHAIN LUBE TO USE? bretzg Tiger Workshop 25 04-01-2007 07:25 AM
Chain Lube - What do you use? danbike Twins Talk 12 04-25-2006 05:14 AM
To Lube the chain or not to Lube...that is the Question Clanrickarde Twins Talk 27 02-25-2006 08:37 AM
Chain Lube pweitz Twins Talk 3 01-01-2006 06:02 PM
Chain Wax vs. Chain Lube Celeste Twins Talk 4 09-01-2005 12:14 AM
