BikeBandit
Old 04-22-2007   #1 (permalink)
What size jets do I need for a 2007 Bonneville Black (Thruxton needles / 40 Pilots) using Togas with and without the baffles? (Stock Airbox / Stock filter).
I don't see this on Jenks PDF.
Please help.
[ This message was edited by: JKDJose on 2007-04-22 20:50 ]
2007 Bonnie Black, M-Bars, NARK, 140 mains, 42 Pilots, Triumph City Bag Black, -20 mm Hagon Rear Shocks, Hagon Progressive Fork Springs
JKDJose is offline   Reply With Quote
Old 04-23-2007   #2 (permalink)
leaving the air box stock, I would try a 120 main, with 3.5 turns out on your pilots
If it seems hard to start and "surges" at low rpms, go to a 42 pilot. If it does not soar to redline in top gear or 4th, go to a 125 main.
G
I just wanted to ride
Old 04-23-2007   #3 (permalink)
webonnielad's Avatar
Ask the man himself?
Norman hyde
webonnielad is offline   Reply With Quote
Old 04-23-2007   #4 (permalink)
Sorry try again!
Norman Hyde
Old 04-23-2007   #5 (permalink)
Cool thanks for that link. I did email him and I was emailed right away. Thanks!
why Togas?? jerryb Twins Technical Talk 21 01-25-2008 12:46 PM
Whistling TOGAs Husk01 Twins Technical Talk 10 08-22-2007 08:10 AM
NH Togas gdawg55 Twins Technical Talk 14 07-10-2007 04:12 PM
NH Togas on, no re-jetting yet and... Liontari Twins Talk 10 10-02-2005 07:30 PM
T-Bird - Togas & jetting question Stormin Hinckley Classic Triples 3 06-03-2005 04:29 PM
