rust spots - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsNew BonnevilleSportbikeTrackGearMotorcycle.com Classifieds!
Old 04-20-2007, 10:46 AM   #1 (permalink)
Now that spring is here (YEEEEHAWWWW!!), i have noticed little rust spots have started to form on my rims and Rentec rack. How should I deal with this? Steel wool? How do I keep it from reoccurring? Is there some kind of rust preventative stuff?? :???:
bonnienewbie is offline   Reply With Quote
Old 04-20-2007, 11:11 AM   #2 (permalink)
Favourite Bike: 02 Bonneville
ivar's Avatar
Other Motorcycle: 93 Dnepr MT-16
Extra Motorcycle: 05 SV650S
I would not use steel wool, it could scratch up the chrome and just make it easier for new rust to form. Spray it with WD-40 or similar and wipe off with a rag, should wipe right off if caught in time.
Could also use some stainless steel polish, it will also protect it from further corrosion if you apply regularly.
02 Bonneville - 904 wiseco/813 cams/FCR carbs/Dominator touring, ARK,AI,.Pieman igniter. Thruxton seat, superbars raised 1". Intiminators/Öhlins PL36 shocks, renntec rack.. Tourance tires , D9 bracketry
ivar is online now   Reply With Quote
Old 04-20-2007, 03:24 PM   #3 (permalink)
MAR
Favourite Bike: Thruxton
Other Motorcycle: Ducati 916
Extra Motorcycle: Aprilia Falco Laverda Mir
I know what I am about to say is strange. However it does work. Clean it with aluminium foil and coke.
"What are you rebelling against?"
"What have you got?"
MAR is offline   Reply With Quote
Old 04-20-2007, 04:12 PM   #4 (permalink)
I'd say metal polish, then a coat of wax. Thats what I 've done since day 1, and no rust
G
I just wanted to ride
Old 04-20-2007, 06:27 PM   #5 (permalink)
webonnielad's Avatar
give it a wipe with WD40 then keep it polished with pledge, both are non abrasive, metal polish will eventually compound the problem.
webonnielad is offline   Reply With Quote
Old 04-20-2007, 10:02 PM   #6 (permalink)
If the rust looks like it's around the spoke holes in the rims (as mine was) you should be able to get your dealer to put in a claim, & get a new rim fitted.
using a macbook pro,Street Triple and a 1958 Land Rover. (wife has a british built Honda)
Dickie2679 is offline   Reply With Quote
Old 04-20-2007, 11:06 PM   #7 (permalink)
Get used to it- very common on the Triumphs. Lousy chrome!! If its surface rust- use WD or some mildchrome cleaner. If the rims are like mine - use never dull & some wax/ polish. I keep on top of mine wipe w/ rag- polish after rides. No detail- just a quick wipe. Keeps things under control! GREAT BIKES- LOUSY CHROME!! Gotta take the good w/ the bad.
CAPT D
brown spots blackbird Twins Technical Talk 10 11-10-2007 09:57 AM
The little oil spots... trumppa Speed Triple Forum 14 08-22-2006 10:53 PM
Flat spots? IamNeighbordave Hinckley Classic Triples 1 06-01-2006 03:43 PM
Coloured Spots.... mrober Speed Triple Forum 5 02-04-2005 11:49 AM
Flat torque spots? LiveTheDream Speed Triple Forum 2 06-26-2004 03:16 AM
