Buy Your 39mm Keihin FCR Flatslide Carb Kit Here - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 04-19-2007, 04:04 AM   #1 (permalink)
Favourite Bike: 2006 Thruxton 904
robnobrakes's Avatar
Other Motorcycle: 1994 Ducati 900SS
Extra Motorcycle: 1998 Tiger 885
This is the company that delevoped the kit for my Thruxton. Brian is most helpful and I have no hesitation is recommending his services. Disclaimer: I have no links (financial or otherwise) with this company, other that as a satisfied customer. If I find a company that provides excellent service and products, I like to pass it on for others to benefit.
http://brspecialtuning.co.uk/Keihin.htm
PRICES:
Kit with Red 35mm plastic funnels: £799.00
Kit with air filter adaptors: £849.00
Kit with adaptors & K&N/DNA filters: £899.00
PLUS DELIVERY.
UK £10.00
Europe £30.00
USA/Canada £40.00
Far East/Australasia £45.00
Rest of the World £50.00
DYNO RESULTS (Please note that the modified head contributes significantly to the results shown below):
Rob
Thruxton 904 :::: BritishMotorcycleGear.com Bike of the Year 2010 - 2011 ::::
Gallery http://www.triumphrat.net/memberalbu...ry.php/cat/524
robnobrakes is offline   Reply With Quote
Old 04-19-2007, 06:04 AM   #2 (permalink)
Favourite Bike: '04 Thruxton
agro's Avatar
Rob,
does this blokes kit utilize the TPS system???
Cheers.............Agro
"Whale Oil Beef Hooked"
agro is online now   Reply With Quote
Old 04-19-2007, 06:15 AM   #3 (permalink)
agro's Avatar
Rob,
Old 04-19-2007, 10:35 AM   #4 (permalink)
Hi agro
Yes, its connected. I'm not too sure if its needed though. You can see it in the 1st photo.
Rob
Old 04-19-2007, 09:06 PM   #5 (permalink)
agro's Avatar
Rob, thanks for the Photo's, noticed that the adapters on the carbs to the rubber manifold connectors are fairly long, is it possible for this kit to be adapted to stock airbox, as I am running a modified airbox with a unifilter.
Cheers...............agro
Old 04-20-2007, 03:34 AM   #6 (permalink)
According to British Customs, these carbs cannot be fitted with the stock airbox in place.
I would strongly recommend that you replace your modified airbox, with an airbox removal kit, or cut the existing airbox as has been shown here in other posts, fit K&N pod filters and gain an easy 5+BHP and a few extra ft/lbs of torque.
Rob
Old 04-20-2007, 05:32 AM   #7 (permalink)
i would luv to see these carbs and the mikuni 42's run head to head, be interesting
ftl40 is offline   Reply With Quote
Old 04-21-2007, 12:20 AM   #8 (permalink)
Favourite Bike: 1087 Triumph
Bonnie1000th's Avatar
Other Motorcycle: 1250 GSF
You can also use these intake manifolds.
Bonnie1000th is offline   Reply With Quote
Old 04-21-2007, 01:33 AM   #9 (permalink)
Hi Bonnie1000th
Your intake manifolds are the ones offered by British Custom, aren't they? I will be fitting these, as they will properly align my carbs. The stock rubber 'boots' are not strong enough.
Rob
Old 04-21-2007, 11:12 PM   #10 (permalink)
Hi Rob:
My are from SBT, but British Customs offers those too.
It really works well, the fitments and carbs alignment is great!!
I have a question : what was your A/F ratio in the dyno run that you posted?
many thanks!
Thruxton - Next Modification Under Way, Keihin 39 FCR FLatslide Carburettors robnobrakes Club Cafe' 21 09-05-2010 12:14 AM
FCR 39mm or CR 35mm MaxH Twins Technical Talk 0 09-18-2007 04:35 PM
39mm Keihin FCR tuning Retro-Racer Twins Technical Talk 8 09-15-2007 12:53 PM
FCR 39mm linkage - how does it work? Oz___ Twins Technical Talk 2 08-19-2007 03:27 PM
Keihin FCR 39mm Flatslide Carbs robnobrakes Twins Technical Talk 20 04-24-2007 06:05 PM
