04-18-2007, 11:50 PM
Formula Extreme Favourite Bike: o6' Blk Triumph SpdMstr.
Posts: 650 Other Motorcycle: 80' Blk Kawasaki KZ550-C1
I've heard many good things about the TBS needles that they have a good taper and that they seem to be the thing , but not exactly an even one (taper) wheras the thruxton has a markedly tapred needle. Can anyone find any difference performance -wise between the two. SMK :hammer:
[ This message was edited by: speedblastr on 2007-04-18 21:53 ]
"At times Ya' have to hold a candle to the Devil." ~06' Blk-SpdMstr~130/40,TBS Ndls.-1Shm.,3T,AI out,Plrs-Blmth,UNI,Th-Bi.-pipes
04-19-2007, 05:11 AM
I went for the Dynojet needles, they seem to have a more agressive taper, and also have the benefit of 6 height settings for tuning.
Ride a Motorcycle....not a Bandwagon..
04-19-2007, 08:13 PM
Bluespoke ,did the dyno-jets come in the kit? I see that you freaked your air on your bike;raised your mains by 25 pts. , raised your pilot jets bt 2 pts. Is there a remarkable difference in the way the bike reacts-throttle pos.-midrange with the dyno needles ,freak and the jets? Did you have the jets that you needed according to a jet calculator or did you have to do some jet swapping? Thanks for the info-I'll look into it. :hammer:
04-23-2007, 05:28 AM
blaster, the Dynojet kit came with 4 sets of jets, but the largest ones were 135 equivalent (they use their own numbers) so I got some after market 145's. The motor is like a beast now, instead of getting breathless, and dying from 3500 on, she goes harder, and harder, all the way to the limiter. I was shocked at the difference. Very rideable, and smooth. Hope this helps.
04-23-2007, 06:30 PM
Yeah, theres a big difference. The length and taper are the 2 variables. The thruxtons are shorter therefore they deliver fuel with a shorter throw of the throttle. The TBS seem to be a bit thinner on the taper, but thats at the end and because they are considerably longer they never get as high up into the jet as the thruxtons do.
What i found was that with 3 shims thew TBS were just slightly less rich than the thruxtons which were TOO rich in my bike even with no shims and a uni filter, thunderbike pipes, 130 mains and drilled airbox. The TBS however were just short of being too rich with 3 shims and performed very similar to the thruxtons with no shims. The differences were as follows..
thruxtons seemed to hav a very slight advantage when coming from a dead stop while winding her up.
the TBS w/3 shims had about the same amount of advantage in a mid range roll on as the Thruxtons did from a dead stop. Being the midrange roll on was more important to me i went with the TBS
And lastly, and another reason i went witrh the TBS w/3 shims is that the thruxtons were just a bit too rich and caused the bike to ***** out badly at the limiter much worse than the TBS. The bike would die and sometimes not start firing again till i was at a dead stop and had to restart it.
I would recommend TBS and shim as much as you can w/o going too rich, which will of course depend on your setup/mods. That is, unless you use an airbox removal kit like the Freak in which case the thruxtons may be just fine. Anyways, thats been my experience with them. YMMV.
04-23-2007, 08:42 PM
Thanks to both of you guys , If you were here I'd by ya' A beer. These days as I approach the half-century age (3 more years) If I knew then what I know now , I'd probably have a whole lot of everything.(A lot of wine,women and song.$$$) Anyway these are the answers(start-up,Midrange) that I've been searching for , as I"m not as hasty as I was when I was 18, Autos maybe;but not motorcycles because _now_ I_ see_ all the time,preparation and let downs. I guess you could call it divine-dissatisfaction. Daz on a light note : I owe you an apology. I replied on a post of yours (my dillema) that was totally retarded.  I :roll: see that there's a lot of thought and effort into these bikes as I can read well.(one could say that I was on a cloud with the TB pipes) It doesn't end there, does it......Thanks a million ,you guys ,I will finally come to a decision on this bike. Hey, spoke :hows the weather from the land down-under! :hammer: daz - beautiful bike. :hammer:
[ This message was edited by: speedblastr on 2007-04-23 18:43 ]
04-26-2007, 06:53 AM
blastr..... it's always good ridin' down here, mate. Put about 600-800kms a week on the Speedy. Coming into winter right now, thats about 18o C overnight, and 27oC daytime. Gets down to about 8oC overnight dead of winter, so we ride all year here. Cheers.
04-26-2007, 12:33 PM
O.K. spoke I'm from america here trying to calculate18oC (64degrees F) 27oC (80degrees F) Dead of winter 80C? correct me if you can. :brk: In grammar school and high school we were taught standard unit of measurement(class of 78') When they infused metrics later on , we were all about half lost. Steven. :???:
04-26-2007, 02:01 PM
I think I see what Daz was telling me through his experience with the needle thing.(THROTTLE POSITION)Needle dia. from 1/16 to a little over 1/2 (with it's peak at 1/4 throttle);Needle clip position or shims 1/4 to 3/4 throttle (with it's peak at a little less than 1/2 throttle);Needle taper1/4 to almost WOT(with it's peak at a little over 1/2 throttle.){Jenks Bolts Effect on fuel flow .vs. Throttle opening chart} Never really stood out until I read his reply post. Again of course this all hinges on modifications as he said. Thanks. :hammer:
[ This message was edited by: speedblastr on 2007-04-26 12:31 ]
