AdvanstarMotorcycleShowsBikeBanditMotorcycle.com
ShopTriumph.com
Old 04-16-2007   #1 (permalink)
MAR
Favorite Bike: Thruxton
Other Motorcycle: Ducati 916
Extra Motorcycle: Aprilia Falco
I have seen a lot of discussion about tires and how they LOOK. My friend and I are having a discussion about what size makes for the best handling bike. His position is that the wider the tire the slower it makes the bike. While I agree to a point, I feel that if the tire profile is higher it will quicken it, then you can have the quickness with a larger patch.
I am thinking about a 140/90 for the rear.( stock Thruxton wheel)Is this a taller than stock tire? Is there any feedback about the optimum tire size. I suspect tire brand will need to enter the discussion as well.
Thanks
"What are you rebelling against?"
"What have you got?"
MAR is offline   Reply With Quote
Old 04-16-2007   #2 (permalink)
Favorite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
Yes, a 140/90 is quite a bit taller than stock. The stock 130/80 is (nominally) 104mm tall (10.4cm ~= 4.1 inches) - 80% of the width, 130mm. A 140/90 is (nominally) 126mm tall (12.6cm ~= 5 inches) - 90% of the width. I don't think you'd want to put that tall of a tire on one of these - it would change the handling quite a bit, I think, as well as the gearing. It would be like switching to quite a bit bigger front sprocket - you'd drop RPMs at the same speed, but at the expense of performance. Also, if you kept the stock front tire, the rear would sit quite a bit higher relative the front than it currently does.
Just my $0.02.
[ This message was edited by: lindsayt on 2007-04-16 11:35 ]
38% rocker, 30% mod.
lindsayt is offline   Reply With Quote
Old 04-16-2007   #3 (permalink)
MAR
Just my $0.02.
Having said that, a lot of guys, drop the triple trees down as much as 25MM. I would "assume" that raising the back up a little has the same effect as lowering the triple trees but without losing stability or ground clearance.
Tire size question AVM Tiger Chat 3 08-02-2007 09:34 PM
Handling problems on my RS and tire question. BlewBayou Sprint Forum 9 10-17-2005 09:38 AM
tire size? nyolds Daytona Deliberations 6 07-18-2004 10:53 PM
Replacemnt tire size????? Trophy 3 03-19-2004 06:15 PM
Tire size Modifications & Workshop Talk 0 05-09-2002 01:25 PM
