Old 04-16-2007   #1 (permalink)
I'm ready to start doing my own maintenance on my 2007 T100. I know keeping the chain properly adjusted is important, and relatively easy. I'm out to buy a torque wrench later this week, as well as other tools I'll need. Does anyone know what the sizes of the axle bolts are on the rear? Also, any recommendations on a torque wrench. Sears has a couple on sale right now, but wasn't sure if anyone had any experience with them.
Thanks!
SoCalNewbie is offline   Reply With Quote
Old 04-16-2007   #2 (permalink)
Favorite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
Okay, so I have this beautiful torque wrench my brother gave me for Christmas, but it's still in its box because I'm afraid to ruin it. How do you use it? Do you tighten the bolt to about what you think it should be with a regular socket set and then just check the torque with the torque wrench, or do you crank it down with the torque wrench itself? I've never used one (despite doing a lot of 2-stroke engine work :razz: ) and am embarrassed to admit I don't really know how to...
38% rocker, 30% mod.
lindsayt is offline   Reply With Quote
Old 04-16-2007   #3 (permalink)
All - thanks for the information. One more question. The right rear axle bolt is pretty close to the exhaust. Do you remove/loosen that when you do the chain adjustment, or will a socket fit on it? If you have to use an open end wrench, how to you verify torque? Do you use crow foot wrenches? I have the Haynes service manual, but it's not very clear on that.
Thanks!
Old 04-16-2007   #4 (permalink)
Favorite Bike: 05 Bonneville T100 B/W
wenzel850's Avatar
Socalnewbie,
In order to adjust the chain you must loosen the axle nut.
Try and find a Sears torque wrench that also measures in Newton Meters. Its the scale used by the Triumph factory, so all the torque specs are stated in such. Sears does make a t/w with Newton Meters on 1 of the scales.
Quentin
"01-20-2009 I can't wait"
wenzel850 is offline   Reply With Quote
Old 04-16-2007   #5 (permalink)
Quentin, thanks for answering so quickly. I didn't ask my question very clearly. I should have asked "How do you loosen/tighten the right rear axle bolt?". Can I fit a regular socket on it , or do I have to use an open ended wrench? If I use an open ended wrench, how do I verify that I've torqued it correctly when I tighten it? Do I use a crow foot wrench with my torque wrench? Alternatively, do I remove or loosen the exhaust and use a socket?
Thanks, SoCalNewbie
Old 04-16-2007   #6 (permalink)
Favorite Bike: Modified 2005 T100
Other Motorcycle: 1994 CB750
I havent adjusted my chain for over 1000 miles, and it is still perfect tension. It is unbelivable
Every sunday is mad sunday.......
BeastInBlack is offline   Reply With Quote
Old 04-16-2007   #7 (permalink)
Favorite Bike: My Bonnie
Other Motorcycle: My other Bonnie
Extra Motorcycle: '98 FXD
If you use a crowfoot on your torque wrench the readings will be wrong...you can compensate (calculate) but once you are off dead center, the torque readings will be a calculated value applied to your clicker.
Shoot safe, straight and often...
BILLYSIM is offline   Reply With Quote
Chain Adjustment Silverado57 Twins Technical Talk 2 05-02-2007 01:59 PM
Chain Adjustment cak03 Sprint Forum 5 06-08-2006 04:45 PM
Chain adjustment? My chain is too slack, cant adjust. roadkill Speed Triple Forum 5 11-22-2005 07:11 AM
chain adjustment RobUK Tiger Chat 4 07-19-2004 04:13 AM
chain adjustment Tiger Chat 4 06-09-2004 05:33 AM
