BikeBanditMotorcycle.comAdvanstarMotorcycleShows
ShopTriumph.com
Old 04-15-2007   #1 (permalink)
Anytips for removing the carbs for rejet? Should I just remove the intake clamps and leave the exhaust side alone?
Also 110's seem to restrictive.. is it OK to put in 115's with a Baffeloctomy?
[ This message was edited by: JKDJose on 2007-04-15 22:44 ]
2007 Bonnie Black, M-Bars, NARK, 140 mains, 42 Pilots, Triumph City Bag Black, -20 mm Hagon Rear Shocks, Hagon Progressive Fork Springs
JKDJose is offline   Reply With Quote
Old 04-16-2007   #2 (permalink)
Favorite Bike: My Bonneville of course
What pipes you using?
No need to go through the hassle of removing the carbs for rejet. Can get to everything with the carbs on. Kinda pain to get to the bottom of the carbs but less or a pain than yanking the carbs.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 04-16-2007   #3 (permalink)
Baffelectomy, missed that sorry.
I was running bubs and stock airbox on the 10's and without knowing by running a dyno it felt OK till I took the snorkle off, added the polaris bellmouth, removed the restrictor plate and added a UNI filter, then went to 118. I think I used the ever so famous dinqua jetting calc to verify closeness.
Old 04-16-2007   #4 (permalink)
Favorite Bike: 2005 Triumph Bonneville
psasak's Avatar
Other Motorcycle: 1968 BSA A65L Lightning
Extra Motorcycle: 1972 Triumph TR6R
This is what the bottom of the carb looks like... You don't need to take them off to re-jet. Get familiar with where things are and go to town!
2005 Triumph Bonneville:
18 tooth sprocket, 135 Mains, 40 Pilots, 1 shim/Thruxton needles, no AI, K&N filters, Emgo Slip-Ons.
My Photo Album
My Bonneville Film Clip My BSA Film Clip
psasak is offline   Reply With Quote
Old 04-16-2007   #5 (permalink)
Most excellent visual aid.
Reckon it would be prudent to mention the carb screw (allen head stainless steel) from www.newbonneville.com that makes going back together and getting back inside much easier.
Old 04-16-2007   #6 (permalink)
Thanks for the info. Carb screws were already done.
I really appreciate all the help!! THANKS A BUNCH!!
[ This message was edited by: JKDJose on 2007-04-16 10:09 ]
Old 04-16-2007   #7 (permalink)
Favorite Bike: 05 Black Speedmaster
Psasak, nice visual aid :upthumb:
Old 04-16-2007   #8 (permalink)
webonnielad's Avatar
Jenks Tuning Notes
more useful info
still more useful info
Check these sites out. Reckon that'll do it.
Jon (UK)
webonnielad is offline   Reply With Quote
Old 04-16-2007   #9 (permalink)
Sorry I forgot to add this useful little video.Airbox removal/re-jet etc.
Jon (UK)
Scrambler snorkel removal - jetting? Texascat Twins Technical Talk 23 02-16-2008 10:19 PM
Carburetor Operation jimmyj900 Modifications & Workshop Talk 6 10-11-2007 11:18 AM
Carburetor screws stu Twins Technical Talk 17 04-20-2007 05:49 PM
Thruxton Jetting with BC predetors and air box removal kit listo Twins Technical Talk 23 11-17-2006 11:35 PM
Carburetor Schematic? AllanCook Twins Talk 0 07-11-2005 06:07 PM
