Old 04-15-2007   #1 (permalink)
Just looked under the carbs today while installing the allen head carb screws and noticed that the idle mixture screws are not a standard screwdriver.. do i need a special tool?
Is anyone running Togas with stock airbox? If so, what size jets are you using?
2007 Bonnie Black, M-Bars, NARK, 140 mains, 42 Pilots, Triumph City Bag Black, -20 mm Hagon Rear Shocks, Hagon Progressive Fork Springs
JKDJose is offline   Reply With Quote
Old 04-15-2007   #2 (permalink)
It's called a "D" tool...Newbonneville.com sells em and probably other vendors. You can make one for temp use by using a piece of small copper tubing and shaping it with pliers, or you can make a more permanent one with a few hand tools and patience. Mine doesn't take a "D" tool--too old--but if it did, I would probably just order one and spend my time riding. :-D
Larry
Larry
Old 04-16-2007   #3 (permalink)
Favorite Bike: My Bonnie
Other Motorcycle: My other Bonnie
Extra Motorcycle: '98 FXD
One guy said he just flattened the side of an M-16 cartridge (.223 Remington= 5.56 Nato) to make his "D" tool.
...Billy
Shoot safe, straight and often...
BILLYSIM is offline   Reply With Quote
Old 04-16-2007   #4 (permalink)
webonnielad's Avatar
D Tool or alternativley Thumb Screws
I used a D Tool to get mine out and replaced 'em with the thumb screws.
Jon (UK)
webonnielad is offline   Reply With Quote
Old 04-16-2007   #5 (permalink)
Favorite Bike: 2003 Triumph T100
I also used the thumbscrews. They're nice for making adjustments on the fly...
How Much For Dealer To Adjust Mixture? Bonnebret Twins Technical Talk 5 09-18-2007 04:58 PM
D shaped tool for idle mixture sweatmachine Twins Talk 24 08-02-2006 07:15 PM
special tool keen Twins Talk 4 01-23-2006 09:19 AM
Need a tool for adjusting mixture screws Modifications & Workshop Talk 11 04-09-2005 08:58 PM
Valve adjust tool...Where is it???? yerguy Sprint Forum 3 06-08-2004 10:30 PM
