Old 04-15-2007   #1 (permalink)
Backyardmech
HI all, this is my first post here. I am in the process of customizing my 06 Bonneville Black. Changed the bars to a flat track bend and was able to reroute my cables to work, but the clutch cable is a couple inches shorter than it should be. I need to replace it anyway as it tipped over and damaged the lever end. Would the America or Speedmaster cable be 2-4" longer? None of the dealers in my area have any in stock to compare. I'm just about done with my project and hope to post some pics in a week or so.
Old 04-15-2007   #2 (permalink)
You might consider making it a little easier to answer your question; i.e., measure the length of your cable and ask if someone will measure the length of their TBA and Speedy cables. The aftermarket vendors sell longer cables for some of their handlebars. I would check the price of these before I bought a Triumph one--might save you some money--and they will know the length of their longer cable, also. :-D
Larry
Larry
Rivco Risers and cable lengths RoadVenture The Rocket Science Forum 2 01-16-2008 07:50 AM
Clutch Cable vanpraag Sprint Forum 6 02-07-2006 11:41 AM
Need clutch cable!!! bennybmn Twins Talk 3 09-15-2005 09:23 PM
America Cable Lengths Bronson33 Twins Talk 0 07-25-2005 10:32 AM
Clutch cable lengths b50bsa Sprint Forum 4 06-27-2005 08:29 PM
