Old 04-14-2007   #1 (permalink)
RT
Favorite Bike: 06 Tang & Opal T-100
RT's Avatar
Other Motorcycle: 06 Tiger Caspian Blue
Extra Motorcycle: 07 America Black & Chrome
No sure the best way to describe this. Sometimes when shutting off my T100 I get a noise that sounds like a starter spinning after the motor shuts down. Does not happen all the time. Anyone else experience similar situation. I always use the toggle switch on grip to shut down the motor.
RT
Confused and Prone to Wander
RT is offline   Reply With Quote
Old 04-14-2007   #2 (permalink)
Favorite Bike: 2005 Bonneville T100 (B&W) - Chromed like a Harley
raproe's Avatar
Thats what it sounds like on mine when I turn off the engine with the kill switch. I usually don't do that but use the key instead.
Rich
"....by its very nature, a single-tracker is in unstable equilibrium, i.e., it cannot, when stationary, stand up by itself."
raproe is offline   Reply With Quote
Old 04-14-2007   #3 (permalink)
I get the same sound on cold days when she runs for 4 or 5 seconds and cuts out when trying to get her started. Not every time, just on occasion, but only when it stalls out. Nothing to worry about. Don't think it has much to do with method of shutting off? Maybe try using the key. Might make a difference. I use the key, many others use the "kill switch" as you described. Happens to everyone.
[ This message was edited by: Jimi_X on 2007-04-14 14:57 ]
Jimi_X is offline   Reply With Quote
Old 04-14-2007   #4 (permalink)
I get that sound as well - probably 30% of the time I shut the machine down. I just attributed it to whatever starting mechanism is used, as if the starter spins a bit. It' s has never worried me.
davidc is offline   Reply With Quote
My last dyno run Saigon5 Hinckley Classic Triples 19 07-31-2006 09:31 AM
Could of out run them on an S3 jackelmatador Speed Triple Forum 6 06-23-2006 11:47 AM
bottesford run malc Tiger Chat 0 12-10-2005 09:48 AM
What does an S3 run in the 1/4? Jonathan Speed Triple Forum 5 11-24-2005 06:57 PM
my first run Celt Speed Triple Forum 6 06-02-2005 05:30 PM
