1st dyno run, opinions and sugestions? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-12-2007, 04:47 PM   #1 (permalink)
Put my bike on the machine for the first time today. Looks pretty good to me. Max HP 65.88 Max Tourque 54.32. Mixture looks a little lean, around 14:1, but takes a dip in the 4100 to 5300 range to about 12.9. Set up is TOR's, home airbox removal, K&N pods, 138 main, 42 pilot, 1 shim, slides drilled to 1/8. Wondering if I should try to enlage main to 140 and ditch the shim, or am I being to picky and I should leave well enough alone? Do ya'll think that would smooth the air/fuel to a good 13? Also thinking that this was at 74 dgrees at 30 percent humidity, that's alot of air for my neck of the woods. normal days coming will be 90+ and around 60-80 percent humidity. probably a better mixture then? I hope this works, first pic post!
AVMECH is offline   Reply With Quote
Old 04-12-2007, 04:54 PM   #2 (permalink)
Main Motorcycle: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
Extra Motorcycle: 2012 Ivory Stella
I'm sure that 99.9% of the people around here are more qualified than me to give an opinion, but that looks incredibly good to me - nice and smooth hp and torque curves, and except for that one dip, a nice even mix line. Of course, I'm used to staring at dyno readings for two-stroke singles with Dell'orto carbs, which are downright insane compared to these, but MAN! I'd be really happy with that myself.
2005 Aegean Blue Bonneville - Intiminators and Thruxton preload adjusters up front, Ikon 7613s in the back, otherwise stock
2012 Azzurro Fiat 500 Sport
lindsayt is offline   Reply With Quote
Old 04-12-2007, 05:09 PM   #3 (permalink)
now that I can post pics, here's my ugly mug. Yeah, I know I'm skinny, that's why I'm so fast!
Old 04-12-2007, 05:12 PM   #4 (permalink)
I'm not "qualified" to give an educated opinion.... but here goes anyway:
Yeah..... I'd go up to some 140's, maybe even some 143's. You are at your leanest where you would normally find yourself cruising on the freeway.... you don't want it running hot while cruising.
I'll be willing to bet that it's pretty responsive to throttle input though! A lean condition can actually make your bike pretty peppy when opening the throttle.
I might also add that all of my Dyno runs show lean conditions at the lower RPM's, and that characteristic dip. Otherwise, that thing is smooooooth!
- 'Rider' -
Click here for a view of my Member's Album.
FattRat is offline   Reply With Quote
Old 04-12-2007, 05:28 PM   #5 (permalink)
Main Motorcycle: My Bonneville of course
I am of the same opinion, at least go up one size, if the dyno ain't too spendy to use then go for another run and see.
Skinny is good, if the old rule of thumb of 7lb = 1hp ....well nuff said. I am also "thin" like to call it an athletic build, makes me feel better about myself. If I weighed what THEY say I should I would be loosing several hp the way I see it.
Nice bike, making good hp, just hope you got good roads in your neck of the woods to run it on.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 04-12-2007, 05:33 PM   #6 (permalink)
TCL
Main Motorcycle: 2007 Bonneville T-100
TCL's Avatar
I'd be pretty happy with those results, good HP and torque.
To quote The Humpty Dance, "Look at me, I'm skinny! It never stopped me from gettin' busy!" :
Death or Glory
TCL is offline   Reply With Quote
Old 04-12-2007, 06:40 PM   #7 (permalink)
Main Motorcycle: 2003 Triumph T100
Sheepdog's Avatar
That curve looks too good to screw around with. Like you, I'm guessing that it will enrichen in warmer weather.
Old 04-12-2007, 08:51 PM   #8 (permalink)
Main Motorcycle: '06 Bonneville Black
SCCTrim's Avatar
Other Motorcycle: '89 FXR
I responded to your same thread in the cafe section. Looking again at your chart, I'd go up to 140 on the main and possibly a 45 pilot.
Bill Gately states these motors perform best with a a/f ratio of 13.2 to 13.7 Your close.
http://nailyourtrim.com
SCCTrim is offline   Reply With Quote
Old 04-12-2007, 11:54 PM   #9 (permalink)
SCCTrim, I saw your repley and replied in club cafe. I hate posting in two forums but I always get responses fom different people in each and for this I wanted all the feedback I can get. So there you can read what I think about the 45 pilot and I think I'll try the 140. The dyno operator also suggested a larger pilot but I really think in my situation it is not benifical.
Vertwrks, if I could get this thing to make 8 more ponies, I'd have half my weight in horsepower!
Old 04-13-2007, 12:40 AM   #10 (permalink)
Remove the shim, 145 main and your weight in kg should do it
jojje1963 is offline   Reply With Quote
1st dyno run, opinions and sugestions? AVMECH Club Cafe' 6 04-13-2007 12:05 AM
Dyno run after re-jet. Opinions wanted. BadMouth Hinckley Classic Triples 5 08-23-2006 06:53 PM
S3 Dyno Run Speed Triple Forum 8 12-11-2005 10:10 PM
1st service done and Dyno run kbbeckius Speed Triple Forum 9 08-12-2005 01:38 AM
