Old 04-12-2007   #1 (permalink)
I am new and want to know the following:
I want to know what kind of chain lube to use.
I want to know what kind of oil to use.
I want to know what air filter I should buy.
I want to know what kind of pipes I should get.
I want to know what size front sproket I should put on.
I want to know how to take my seat off.
I want to know what air pressure my tires should be.
I want to know if I can remove the airbox without rejetting
I want to know the capital of south dakota. (Never mind I found the answer at wikipedia.com)
Thanks for all your help and I hope you all realize that this was meant to be humorous.
Scott
From Winston-Salem, North Carolina, USA
Think you can, Think you can't, either way you're right.
merlotlover is offline   Reply With Quote
Old 04-12-2007   #2 (permalink)
Favorite Bike: Tiger 1050
Other Motorcycle: Honda Transalp
So many questions!
I want to know what kind of chain lube to use. Anything decent - though chain wax isn;t very good if you live in a wet area as it doesnp;t protect well against rust. Best to put chain lube on after a ride when the chain is warm.
I want to know what kind of oil to use. The one recommended in the handbook - Castrol 10/40 synthetic bike oil I think. If the bike is running in it should be semi-synth though - or the bike won't run in properly! Check for the correct oil with a dealer if you don't have the handbook.
I want to know what air filter I should buy. If you fit a free-flow air filter, you'll need to rejet - so best to do that when you change pipes so you only have to reject once!
I want to know what kind of pipes I should get. Look through all the posts here - there are dozens of alternatives, depending on how loud you want, whether you want it to look different, etc. Again - you'll need to reject - and you should get rid of the air injection kit too to avoid your pipes getting very hot and bluing excessively.
Depends whether you want better excellration or lower revs at high road speed. Look at the posts - you'll find a lot of advice.
I want to know how to take my seat off. Thereare two allen screws under the rear of the seat - undo them and then pull the seat backwards a couple of inches - you can then lift it off.
I want to know what air pressure my tires should be. Can't remember! I'm at work so haven;t got the owner's handbook with me. Did one come with the bike?
No - not a good idea - the bike will run too lean and could result in engine damage.
Time flies like an arrow...
Fruit flies like bananas
eagle is offline   Reply With Quote
Old 04-12-2007   #3 (permalink)
Favorite Bike: Was 2006 Black Bonneville
oldmanjob's Avatar
Tire pressure is 33 front and 38 back
John 14:6 KJV
Black Bonnie - 06
Looking back to the good old days is not the way out. Looking up to the God of All the Days is. (Vance Havner)
oldmanjob is offline   Reply With Quote
Old 04-12-2007   #4 (permalink)
Have you ever considered using the SEARCH feature? Or more so ... look to the left menu, 4th link down it's called "rat.net.wiki" ... and do a search for Bonneville. The common questions you're asking have been asked time and time again and there aer LOADS of info that have been achived by members here.
Here, I'll help out one step further ... click me
Bonafide is offline   Reply With Quote
Old 04-12-2007   #5 (permalink)
Favorite Bike: 2005 Aegean Blue Triumph Bonneville
lindsayt's Avatar
Other Motorcycle: 2005 Ice Mint Green Genuine Stella
Apparently some people didn't see that part.
38% rocker, 30% mod.
lindsayt is offline   Reply With Quote
Old 04-12-2007   #6 (permalink)
I was trying to be funny and ask the most obvious questions that I have seen time and time again. I just shows you that the people on this board want to be as helpful as possible.
Scott
Old 04-12-2007   #7 (permalink)
That's one way of lookin at it!
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 04-12-2007   #8 (permalink)
Jimi_X's Avatar
Pfffffffffft,......pffft,..pfft................... .................AHHhhhhhhhaaaaa,....cough!, cough!
[ This message was edited by: Jimi_X on 2007-04-12 18:15 ]
Jimi_X is offline   Reply With Quote
In serious need of advice darcon T3 Sport / Touring Forum 14 05-27-2007 07:14 PM
Any advice? Freakazoid84 Sprint Forum 2 04-30-2006 08:45 AM
Help and Advice KevinM Daytona Deliberations 1 08-31-2005 01:44 PM
Need some advice FDCF1 The Rocket Science Forum 2 08-21-2005 10:42 PM
Need Some Advice muss Twins Talk 6 08-15-2005 10:12 AM
