Old 04-06-2007   #1 (permalink)
heading down to the tool shop for some stuff for the new bike.
What are the absolute unmissable tools i should be looking for?
also are there any good manuals for the new bonnies? and where to get them.
There's more to life than living.
bricktop is offline   Reply With Quote
Old 04-06-2007   #2 (permalink)
I've got like a gazillion tools and every one I get I find I 'need' another. So, like where to start? Get them as you need them, unless your rich.
Socket set, open wrenches, hex set,
Click type torque wrench is like, irreplaceable.
Triumnph manual is good, Haynes manual is better (my opinion)
Get none, ride the bike, enjoy.
Be warned though, If you buy the wrenches you'll be addicted. Then you've got a second hobby for the price of the first - good deal.
Number one tool - air pressure gauge.
merlin is offline   Reply With Quote
Old 04-06-2007   #3 (permalink)
Favorite Bike: My Bonneville of course
I am with Merlin, get a touque wrench!
Also the bike lift, about $60 from several sources is awesome. Other than this just score what you need as needs arise. Kinda like making payments.
Rig up a carb synch set up, thats cool to have as well.
Other than the special deals, just a good set of combo wrenches allen wrenches and sockets will get you a long way.
I have the Haynes, tells me everything I need for half the coin of the Triumph manual.
04 Bonneville w/904 kit, 1mm over valves, ported, ARK'd, Bub's, HSR 42's, F3 forks, kyb rear shox, F3 clip ons, Brembo M/C, 6 pot caliper, 17" Excel's, this & that
vertwrks is offline   Reply With Quote
Old 04-06-2007   #4 (permalink)
The best "tool" I bought was a $ 50 electric tire inflator from Sears. I'm much more on top of my tire pressures than if I had to stop at a gas station. Two minutes and my tires are perfect.
Mike
MikeinLA is offline   Reply With Quote
Old 04-06-2007   #5 (permalink)
thanks guys keep them coming. making a list now.
Old 04-07-2007   #6 (permalink)
cool, would the 2001-05 haynes manual do for the 07 bonnie, i assume so.
Old 04-07-2007   #7 (permalink)
Duct Tape for things that are loose and supposed to be tight
WD 40 or things that are tight and supposed to be loose
mrgadget is offline   Reply With Quote
Old 04-07-2007   #8 (permalink)
Other Motorcycle: 66 Bonnie Chop
I love my Craftsman Gear Wrenches. I stashed my old combination wrenches.
Al
ssjones is offline   Reply With Quote
Old 04-07-2007   #9 (permalink)
webonnielad's Avatar
HI
The best general purpose tool I have for my bike "Vice Grips"
the guys on here told me about them.
They were a bit hard to find in the UK, but you can't get into the original carbs or any soft bolts without them.
Once your in you can replace all the soft cross head screws with Jenks stainless hex bolts and save yourself a whole lot of work.
There also very good for getting a grip on anything difficult to access.
Jon (UK)
webonnielad is offline   Reply With Quote
Old 04-07-2007   #10 (permalink)
Favorite Bike: Scrambler
johnyC's Avatar
bricktop,
If your socket set doesn't have one, get yourself a 36mm socket, for the nut on your gearbox sprocket.
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Got some new tools Bonafide Twins Talk 18 09-10-2007 11:00 AM
Tools? Moggy Twins Technical Talk 7 08-01-2007 05:39 PM
D Tools JKDJose Twins Technical Talk 1 04-18-2007 09:19 PM
tools stmike Speed Triple Forum 22 02-12-2007 10:00 PM
Tools mglemans86 Biker Hang-Out 11 01-18-2007 03:06 AM
