Motorcycle.com
Old 04-06-2007   #1 (permalink)
Has any body had problems with the oil seal leaking = oil in the air box. After checking up I found that this seal is the cause of oil "passing" through into the air box = messing up the air filter.
Thank God its Friday again :-g :-g :-g :-g :-g
Coser2 is offline   Reply With Quote
Old 04-06-2007   #2 (permalink)
My 2001 Bonny had that problem. There is a seal that fixes it. It's at the end of the crank on the left side of the motor. Remove left case...Remember to disconect breather tube. Seal comes with plastic tube which goes on shaft. Easy fix mine still is good.
Bobnoxious is offline   Reply With Quote
Old 04-10-2007   #3 (permalink)
Hi Bobnoxious
OK thanks for the tip, Ive ordered the seal and as I'm getting the cover off Ill get the clutch lever seals changed as well. Is there any thing else that could/should be changed ??
Old 04-11-2007   #4 (permalink)
No extra tricks. I tried to take my side cover off befor realizing that the breather tube needs to be disconnected I had a lot of oil getting into the air box which clogged my air filter. I had to show the dealer on his microfish what part I needed. Make sure you replace the plastic piece that goes over the shaft.
Old 04-11-2007   #5 (permalink)
An 2002 shouldn't have a plastic tube, they changed the centrifugal part some time 2001-2002. If it's black it's new, I think the older ones where white?
jojje1963 is offline   Reply With Quote
Blew the oil seal?? pabonne Twins Technical Talk 7 06-11-2007 09:21 AM
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 03:09 PM
Tips for Replacing Countershaft Oil Seal RoundSlide Twins Talk 6 11-03-2006 09:39 PM
fork oil seal replacement. 68tri Modifications & Workshop Talk 2 09-14-2006 05:03 PM
Legend Fork oil seal??? TexasTri Hinckley Classic Triples 41 08-31-2005 08:45 AM
