Motorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 04-06-2007   #1 (permalink)
Favorite Bike: 2007 Bonneville Black
Primo's Avatar
Other Motorcycle: 1961 Ironhead Sportster
Is this normal? Up until today I was only bluing a little at the top.
After the ride in this morning (a little under 30 deg about 20 miles between 65-80 mph) I noticed a whole lot more blue. My bike only has 350 miles on her, the blue doesn't bother me this is just my first NEW bike so everything is worrying me right now.
Thanks,
Primo
[ This message was edited by: Primo on 2007-04-06 07:31 ]
Primo is offline   Reply With Quote
Old 04-06-2007   #2 (permalink)
MattTriumphs's Avatar
yes
MattTriumphs is offline   Reply With Quote
Old 04-06-2007   #3 (permalink)
I see you still have the A?I installed. The entire pipe will eventually turn blue unless tyou disconnect it. It happened to my buds Bonne. Mine & another blued just past the 1st bend A?I gone. Your choice. Can always paint/coat the pipe black- problem solved. DX the A/I & the bluing will stop where it is.
CAPT D
CAPTDON is online now   Reply With Quote
Old 04-06-2007   #4 (permalink)
My Scrambler has no blue at all on the right-side pipe and so far only a few inches with a golden color. That's at 650 miles with the AI system still installed (which, by the way, I don't think I'll remove). But I didn't run the bike up to 80 mph right away, which seems a bit high for under 500 miles. No doubt others would disagree, but until 500 I went no faster than 70.
If the discoloration bothers you at all, you can always get a can of Blue Job (it comes about a quarter full, absurdly expensive) and start rubbing.
snark is offline   Reply With Quote
Old 04-06-2007   #5 (permalink)
Favorite Bike: '06 T100
road_dog's Avatar
Yep... it's normal. Removing the air induction systems helps by decreasing the exhaust temperature. But the thin wall header pipes will turn blue regardless.
However, until you get some matching black saddlebags... I wouldn't be too concerned about the headers. :razz:
Phil (road dog)
Click on the Image
for Larger Picture
road_dog is offline   Reply With Quote
Old 04-06-2007   #6 (permalink)
Primo's Avatar
Heh, I just threw those on because I freeze in the morning then roast with all my gear on in the afternoons. Once I don't need warm clothing anymore, off they go :nana:
Old 04-06-2007   #7 (permalink)
road_dog's Avatar
I was hinting at black bags and black headers.
Cause that would look sweet on a Bonnie black.
Phil (road dog)
Click on the Image
for Larger Picture
Old 04-06-2007   #8 (permalink)
It happened when you left the engine running with the choke on this morn. It happened to me too.
bonnienewbie is offline   Reply With Quote
Old 04-06-2007   #9 (permalink)
Primo's Avatar
Oh I'm deffinately planning on ceramic coated black headers with this exhaust.
Old 04-06-2007   #10 (permalink)
.....and get a Widder Lectric vest. Temperature problem solved.
Scrambler pipe question A2WheelCpl Twins Technical Talk 11 12-09-2007 02:56 PM
Not a blue pipe complaint ... perhaps useful info ohiorider Twins Technical Talk 9 12-29-2006 05:26 PM
Blue header pipe womcat Sprint Forum 0 05-30-2006 08:46 PM
question about blue flame slip on nakedlover Speed Triple Forum 1 05-12-2006 08:39 AM
Pipe Question skrap1r0n Sprint Forum 11 01-23-2006 10:37 AM
