Old 04-03-2007   #1 (permalink)
webonnielad's Avatar
Dear All
I just put Hagon Road shocks on my 790cc 2003 Bonnie. I got the 320mm ones to lower the bike and it works
Great. So thanks for your advice on that.
Also I'd like tell you about the guy I phoned yesterday, at Hagons, enquiring about removing the old swing arm bushes, he saved the day, great service.
My next question!
With the standard springing the triumph Manual for my bike has the maximum fork travel at 120mm.
I have a spacer and end cover kit supplied by (Mecatwin in France) , that allegedly allows me to lower the front end 22mm by raising them above the yolks.
The internal spacers allegedly increase the spring pre-load by 12Nm.
I've just measured the standard distance between the regulator and the front mudguard, with Vernia calipers and it's exactly 142mm.
Which means if the spacers don't work as advertised, It's likely that the regulator will hit the mudguard under extreme braking conditions.
So
Does anyone know if the Hagon progressive front fork springs reduce the length of maximum travel in the front forks?
If so by how much?
Would I still need to use my spacers with the Hagon springs?
I'm really not worried if all I've bought so far is an expensive set of fork top covers.
so if the springs will serve the same purpose or even better surpass it, then for £55 there's just no argument. I just need to know for sure that what I want to do will work.
Please advise.
Thanks in advance.
Jon (UK)
webonnielad is offline   Reply With Quote
Old 04-03-2007   #2 (permalink)
The spacers will still be utilized with Hagons, they are the same length as stock. Your other questions could best (perhaps) be answered by Dave Quinn. He sells and sets up Hagon stuff
G
I just wanted to ride
Old 04-03-2007   #3 (permalink)
Anxiously waiting on the side lines for your answer to come......
While my rear wheel is in for repair, I raised my tubes by the suggested 22mm via Mecatwin (I actually raised them about 3/4"). I haven't ridden the bike yet, so I don't know how it may effect everything. I have Works Performance single rate springs in a pair of Thruxton tubes, so I plan to feel everything out.
Quite a few people have claimed to raise their tubes a pretty significant amount, and I haven't heard of any problems. If anything, it was mentioned that the horn may hit the mud guard on a full tilt braking situation if raised too much in the triple trees.
----- Sa-watdii Thaiumph! -----
Olderyoungster is offline   Reply With Quote
Lowering the front forks... HELP! adamoverdrive Twins Technical Talk 1 07-24-2007 12:05 PM
front forks canadianbonnie Twins Technical Talk 3 06-14-2007 08:19 PM
lowering front forks? RANCAM Twins Technical Talk 4 03-31-2007 11:35 AM
Front forks mshelton Club Cafe 18 03-10-2007 10:42 AM
Extended Forks & Lowering Rearend lrw54 Classic, Vintage & Veteran 29 02-13-2006 05:43 PM
